I have been contemplating this, it is starting to look a little ratty, was wondering if anyone had done this. or if there was any reason ( such as head from the engine bubbling the paint or something.
I need to change mine also. There is no truth to removing it and not installing one to cause your Hood paint to bubble.It is for noise control. Most cheaper cars don't have them. You can use a large tack puller to remove the large plastic retaining pins.
If Im not mistaken it also is a flame retardant and will help put a fire by breaking up and falling down on it, Im not positive however.
Good to know. I love my Vette. However, I coud never feel confident driving a car that had previously been on fire. Consequently, if my Vette ever caught fire, I would want the sucker to keep burning until it turned into a plastic lump.
The Lizzard
Yea Im not sure if it would really help if it started to burn or if it is even designed for that. However I have an el camino that caught on fire from what appears to be a leaky valve cover gasket of which the gasket got pushed out somehow and started to burn. Nothing was messed up other than some burn marks on the valve covers but this also happened after it overheated so bad 6 cylinders had blown the head gasket no clue what temperatures it reached as I was not driving it. I feel confident that I could rebuild the 305 and it would be fine but Im going ot put a 350 in there and go from there.
Yes, I have also heard that removing the hood pad doesn't hurt anything , but it does create more audible engine noise from outside the car, I am getting my 99 vette completely converted from black to mellenium yellow as I write this, and I had the body shop paint both sides of the hood. just going to try it and see what happens, I may get an aftermarket hi-rise in the future anyways.
I removed mine because it was starting to peel... I also drilled out the rivets holding the hood light in place and removed that as well... it is painted but not completely, I like the look of it better without the liner... I may get it painted in the future if I don't go with an aftermarket hood but it's not a big deal to me either way as my hood is closed most of the time anyway
Thanks!
If the liner is just dirty, it's easy to clean. Carefully remove it, then gently brush off loose dirt & debris. Next spray ArmorAllFoamingTireCleaner liberally over the entire surface, let dry for a couple hours, then reinstall. I used one can & got good coverage. The liner looked new when I finished.
