Starter sticking?
Old Feb 21, 2012 | 07:28 PM
mjohnson68's Avatar
mjohnson68
Default Starter sticking?
I have had my C5 in my garage for the last couple months now... Today I decided I was going to take it out for a drive and found the battery dead... I put it on a charger and charged it overnight, today I get a HARD clicking sound... It almost sounds like the solenoid trying to engage but not quite sure... Anyone else heard anything like this?
All of the electrical items in the car work, lights, windows, etc...
Just trying to eliminate some things before I try to remove the starter...
Thanks...
Mike.
Old Feb 21, 2012 | 07:55 PM
JM20's Avatar
JM20
Did you get the battery tested?
I had something similar (would get one click) and found the connections at the starter soleniod were loose.
Old Feb 22, 2012 | 12:28 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is the engine FREE TO TURN????????
I would check that before I went ANY FURTHER. Put it in third gear and have some friends push it forward. Observe the damper and make sure that you can see it rotate several revolutions to make sure that the engine isn't HYDRO LOCKED!!! Just a sanity check that will save you a LOT of money
BC
Old Feb 22, 2012 | 08:55 AM
mjohnson68's Avatar
mjohnson68
Bill unfortunately its an automatic...
As far as the battery it is an Optima Red Top due to the excessive stereo equipment in the car... I also have 2 more batteries in the rear... So I am pretty sure I have power...
I do need to see if I can get it in the air at home here and check the starter wire out tho...
Thanks for the input guys....
Old Feb 22, 2012 | 12:07 PM
BigGun's Avatar
BigGun
Don't forget your dmm. Make sure your getting 12 volts at the starter.
Old Feb 22, 2012 | 12:22 PM
bikerjim2000's Avatar
bikerjim2000
Default it is the battery
Battery, is it holding 12.7 after you charged? Turn on everything , fog lights ac fan etc test voltage again at the battery.or try to start it, I bet the lights go almost out when you try to crank it.
To Starter sticking?
