dash light issue
Old Feb 22, 2012 | 05:13 PM
duramaxmeyer's Avatar
duramaxmeyer
Default dash light issue
battery kept goin dead from sitting put a trickle charge on brand new battery gets fully charged shuts off trickle charger but lights in dash wont go out..... service abs service traction and so on.......anyway to reset them so they stay out once battery is fully charged ??thanks hope its not a dumb question.....its a 2003 anniversary 517 at wheels 150 shot in trunk just incase ya need it
Old Feb 22, 2012 | 06:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
So, if I'm reading you semi-correctly, with the key out, the lights remain on and specifically the ABS light is on and you still have a service message? Have you pulled the codes yet, using the DIC to do so?
Old Feb 22, 2012 | 07:09 PM
duramaxmeyer
no im sorry with it running the lights come on...when i hit reset it will clear the message where the mileage is but the indicator lights stay on in the dash by the gauges
Old Feb 22, 2012 | 08:14 PM
dgrant3830's Avatar
dgrant3830
Then you need to pull the codes from the DIC. Do you know how to do this yet? Its a powerful tool built into all of the C-5's. There are many good writeups here on doing that. Once you pull the codes, you will be able to easily research them or we can tell you pretty quickly where the problem is.
Old Feb 23, 2012 | 03:46 PM
duramaxmeyer
no i do not know how to pull codes on the car....
Old Feb 23, 2012 | 03:59 PM
dgrant3830's Avatar
dgrant3830
Here you go!
http://www.stengel.net/diccodes.htm
Old Feb 23, 2012 | 04:17 PM
duramaxmeyer
thanks i'll give it a shot
To dash light issue
