door control module interchangable?
Old Feb 22, 2012 | 06:30 PM
69SSC5's Avatar
69SSC5
Default door control module interchangable?
driver side door and window work great... passenger window and door are totally dead. took the passenger door apart and just as i thought no passenger door control module. im looking to buy one but I only see driver door control modules for sale. Do i need to purchase a "passenger" door control module or can i buy a driver side door control module and use it on my passenger door?
Old Feb 22, 2012 | 06:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I believe they have different part numbers therefore there is a difference of some sort. I do not know what the difference is. Contact Gene Culley at www.gmpartshouse.com and I'm sure he can assist you. It might only be the serial interface addressing.
Old Feb 23, 2012 | 12:05 AM
Rexde1's Avatar
Rexde1
I thought I saw some on ebay. I was looking at drivers side and kept sing Pass side ones. I still dont know if I need one or its the actuator.
Old Feb 23, 2012 | 07:00 AM
dgrant3830's Avatar
dgrant3830
Have you checked the fuses yet in both of the fuse boxes? Have you pulled your codes yet using the DIC?
Old Feb 23, 2012 | 10:11 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They are different. How much different (not known)
BC
Old Feb 23, 2012 | 10:12 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If it were ME,, I would inspect the power connector inthe door A Pillar hole inside the accordion tube. Could be a female pin issue. They get defomed and make poor contacts.
BC
To door control module interchangable?
