C5 Corvette Braking Problem
Old Feb 28, 2012 | 10:42 PM
ChaseZ06's Avatar
ChaseZ06
Default C5 Corvette Braking Problem
issue resolved
Old Feb 28, 2012 | 11:13 PM
1986coupe's Avatar
1986coupe
If the brake pins aren't lubricated on a regular basis they can compress then not release completely. You can take the calipers off and put some brake lubricant on them then see if that changes anything.
Have you inspected the parking brake recently? They may be dragging. Check the calipers first though.
Old Feb 29, 2012 | 08:27 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
I would also check the rotors for lateral run-out or warpage. This can cause severe vibration when braking from speed. May also be the cause of the spotty deposits on the rotors. GL
To C5 Corvette Braking Problem
