Tire system
Old Feb 29, 2012 | 11:56 AM
spotles's Avatar
spotles
Default Tire system
My tire monitor system light went on. I tried to reset the system but could not get the left front tire to sound the horn, all the others would sound the horn. I replace the sensor on the left front and reset the system, all tires sounded the horn and system reset. The problem I am now having is when I drive the car after about 10 minutes or so the warning light for the tire system comes back on. I then reset the system and the light goes off and system is rest but the light comes back on after a few miles. Any help??
Joe
it is a 2000 Corvette with only 10,000 miles
Old Feb 29, 2012 | 01:13 PM
jim993's Avatar
jim993
Search TPM training, in general section. There are a lot of posts on the system.
Old Feb 29, 2012 | 02:39 PM
spotles's Avatar
spotles
Default Codes
first seven read no code the others not sure what I am looking for. The code go to fast to write them down
Old Feb 29, 2012 | 02:41 PM
spotles's Avatar
spotles
Default tpm
Thanks I have looked and tried reseting it many times
Old Feb 29, 2012 | 03:10 PM
spotles's Avatar
spotles
Default codes
Codes are:
AO-LDCM B2282H,B2284H,U1255H,U1064H,U1016H,U1096 H
A1-RDCM B2283H,B2285H,U1255H,U1264H,U1016H,U1096 H
A6-SCM NO CODES
BO-RFA U1096H,U1064H,U1016H,C2110HC,C2115H
I hope someone can tell me what the codes mean
Old Feb 29, 2012 | 04:41 PM
dblerman's Avatar
dblerman
Originally Posted by spotles
Codes are:
BO-RFA C2110HC
C2110 Right Rear TPM Sensor Malfunction
Old Mar 1, 2012 | 10:01 AM
spotles's Avatar
spotles
Default Codes
Thank You for all the help. The battery is less than a year old and yes I use a battery tender if the car will be sitting more than a week. I reset all the codes now just waiting for a good day to drive the car and recheck the codes. I ordered the sensor for the right rear because it had the code C2110HC. the left rear just had H do you think that needs replacing?
Joe
Old Mar 1, 2012 | 10:16 AM
spotles's Avatar
spotles
Default Codes
Thanks for all the help. It's nice to know how to pull the codes and what they mean. Much cheaper doing it yourself
Joe
Old Mar 1, 2012 | 12:00 PM
spotles's Avatar
spotles
Default codes
Joe
Old Mar 1, 2012 | 12:18 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I ran into one of mine failed many years ago due to the centrifugal switch got stuck and kept it on till the battery died early within it. I replaced it and another since then, with no further issues but yes, two are still the originals so they will fail eventually.
Old Mar 5, 2012 | 10:35 AM
spotles's Avatar
spotles
drove the car today after reseting all code. Still have the c2110 and ordered the sensor for that problem. Today took it in for my Illinois air test and now have code U1096, U1064 and U1016
Old Mar 5, 2012 | 05:48 PM
spotles's Avatar
spotles
Default codes
BO-RFA codes and there was a H at the end of them.
To Tire system
