Clutch Hydraulic Issue
Old Mar 1, 2012 | 05:39 PM
Neil B's Avatar
Neil B
Default Clutch Hydraulic Issue
Hey guys, I'm having trouble with my clutch hydraulics. My Tick MC developed a leak and they replaced it. After installing the replacement, I have bled the system via several methods - the 2 man method via remote bleeder, reverse bleeding/RFI, and vacuum bleeding (Mityvac method). I have performed each method several times and run several quarts of brake fluid through the system. I have a firm pedal, but when I pump the pedal it slowly moves closer to the floor with each pump. The pedal will return to its high position if I give it a rest for a few seconds. When I take the car for a drive, it is fine for the first few clutch engagements and then the pedal and engagement point start moving to the floor. If I put the car in neutral and let up on the pedal for a few seconds, the pedal will rise along with the engagement point. I don't appear to be losing any fluid. My clutch setup is an RPS BC2, GM slave with 300 miles on it, and the Tick MC. What do you guys think? Keep bleeding? Bad replacement master? Other?
Thanks. --Neil
Old Mar 1, 2012 | 05:48 PM
k0ts's Avatar
k0ts
Another bad MC?? that would be my guess.
Old Mar 1, 2012 | 06:13 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
What is the supplier's (tick) recommendation?
Old Mar 1, 2012 | 06:25 PM
Neil B's Avatar
Neil B
Their initial thought was a bad slave. Seems pretty unlikely to me that the nearly new slave would go out when the only thing I replaced was the master. Plus it's not losing any fluid.
Old Mar 1, 2012 | 08:50 PM
bumble-z's Avatar
bumble-z
Hi Neil.
You removed & discarded the black rubber piece on top of the Tick master, before applying the top Tick white resevoire piece?
Old Mar 1, 2012 | 09:13 PM
Neil B's Avatar
Neil B
Originally Posted by bumble-z
Hi Neil.
Hey. Yes, I removed the rubber shipping cap and then installed the press fit white reservoir adapter after putting the master through the firewall. The removal and re-install really wasn't too bad but something's not right in the system. At least I have some nice new bleeding tools to play with.
Old Mar 1, 2012 | 11:44 PM
Neil B's Avatar
Neil B
After thinking about the issue some more, my guess is that the new master cylinder is internally bypassing fluid from the high-pressure side to the low-pressure side of the internal seal. It really seems like the only explanation for why it's losing pressure after pumping or holding the clutch pedal down and then normal travel and pressure returns after a few seconds of release. Thoughts?
I really don't want to replace the master again, but it beats dropping the drivetrain to check the slave.
Old Mar 2, 2012 | 12:07 AM
bumble-z's Avatar
bumble-z
You more than likely don't have stock exhaust & have long tube headers?
Which remote bleeder did you go with & was it new?
Old Mar 2, 2012 | 09:34 AM
Neil B's Avatar
Neil B
I have long tube headers. The remote bleeder is a Tick unit installed new at Vengeance Racing a few months ago. The clutch worked flawlessly before the master started leaking and the new master is the only component in the system that has changed.
Old Mar 2, 2012 | 09:54 AM
bumble-z's Avatar
bumble-z
Sending a pm.
Old Mar 2, 2012 | 10:17 AM
LoneStarFRC's Avatar
LoneStarFRC
After thinking about the issue some more, my guess is that the new master cylinder is internally bypassing fluid from the high-pressure side to the low-pressure side of the internal seal. It really seems like the only explanation for why it's losing pressure after pumping or holding the clutch pedal down and then normal travel and pressure returns after a few seconds of release. Thoughts?...........
This.
Old Mar 2, 2012 | 10:58 AM
Ron@Vengeance Racing's Avatar
0Ron@Vengeance Racing
Former Vendor
Originally Posted by LoneStarFRC
This.
Old Mar 2, 2012 | 12:25 PM
Neil B's Avatar
Neil B
Sounds like it might be time to stand on my head again in the driver's footwell.
Old Mar 16, 2012 | 12:37 PM
Neil B's Avatar
Neil B
I got the new master installed last night and did an initial bleed. It seems to be holding pressure now.
Old Mar 16, 2012 | 12:40 PM
Neil B's Avatar
Neil B
I wanted to add that the guys at Tick have been great to work with on this. They really stand behind their product.
I will get the car on the ground, adjust the clutch, and drive it some early next week. Hopefully, this did the trick.
Old Mar 16, 2012 | 12:46 PM
LoneStarFRC
I have heard nothing but good comments regarding those folks over the years.
Keep us posted.
Old Mar 19, 2012 | 04:03 PM
Neil B's Avatar
Neil B
Problem solved. I took the car for a few laps around the neighborhood and the (2nd) new master cylinder seems to be holding pressure.
Thanks guys.
To Clutch Hydraulic Issue
Old Mar 19, 2012 | 04:10 PM
LoneStarFRC
Thanks guys.
Nice.
Btw, how do you like that clutch? RPS was one of the ones on my list when I was looking for a twin-disc last year. Any chatter all? Does it engage smoothly and is not "grabby"?
Old Mar 19, 2012 | 04:38 PM
Neil B's Avatar
Neil B
Nice.
It requires lots of attention on engagement. It's very much like a race clutch setup with very short engagement travel (like an on/off switch). Other people will argue that this clutch feels like stock and it all depends on how it's set up. My McCleod street twin was much easier to drive. Having said that, the engagement does feel a bit better with the new master installed.
My RPS doesn't chatter on engagement or rattle at idle. You can hear it a bit at idle with the clutch depressed though.
Old Mar 19, 2012 | 05:03 PM
LoneStarFRC
Do you have the lightweight flywheel? This may also cause or aggravate a little bit of the "on/off" factor, requiring a bit higher rpm for take-offs, etc.
I have the McLeod RST and have no chatter issues, but of course it has organic disc surfaces and not Kevlar. Not having any springs (RPS) on the disks has always made me a bit cautious.
I have only spoken to one other person with the RPS and it was over on LS1 Tech and he had it in an F-body. He loves his and says even his wife can drive it on the street.
