Engine Ticking Under Load
Old Mar 5, 2012 | 05:22 PM
Yellow95's Avatar
Yellow95
Default Engine Ticking Under Load
I’ve done some searches and seen many posts about engine ticking. I saw one with my symptoms but it had no cause. So I’ll try again.
2003 ZO6, stock, 89,000 miles. Daily driver, some track sessions. 86k of the 89k miles were put on by me. Trouble free.
I started getting a ticking sound from the front a few months ago and it just started getting louder.
Engine is quiet at idle. You can only hear the ticking under load. Light load is enough. It is quiet at 70 on the highway. It is also definitely RPM related. It is not loud. Sound is completely masked by the radio. If you accelerate hard, the engine sound masks the ticking. There are no codes and the engine seems to run just fine. No water in the oil or oil in the water. This weekend I did a HPDE with no indication of any problem.
I’m thinking exhaust leak or plug wire because of the load factor condition.
I think any mechanical problem; springs, valves, lifters, would be present under any condition and cause some performance issues.
Any guesses?
Old Mar 5, 2012 | 05:46 PM
SaberD's Avatar
SaberD
sounds to me like an exhaust leak. inspect your manifolds and downpipes. usually leaks only tick when they are pretty close to the head.
Old Mar 5, 2012 | 08:09 PM
Jewjenk's Avatar
Jewjenk
Silly question, but are you using PREMIUM gas? Could be that over time carbon has built up, raising octane requirements past using 87...
Old Mar 6, 2012 | 10:45 AM
Yellow95's Avatar
Yellow95
Always using premium gas.
Old Mar 6, 2012 | 12:30 PM
cdkcorvette7's Avatar
cdkcorvette7
Old Mar 6, 2012 | 01:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXHAUST LEAK!!
Had a leak that I didnt know about and found it during my SEAFOAM treatment.
Saw the smoke puff out of the passengers side AIR flange when I started the engine after the SEAFOAM soak. The gasket at the flange was bad.
Jack up the car on stands or on a lift. Plug up the exhaust pipes with rag/s and start the car. If there are any leaks, you will be able to feel the pressure come out of the bad area. Someone may have to hold the rags in the exhaust pipes to help build up the back pressure.. If you have leak/s,, they will easily stay in the pipes!
Old Mar 6, 2012 | 07:13 PM
Underdogg's Avatar
Underdogg
I'd agree with the exhaust leak. If that doesn't work it maybe the injectors ticking when the duty cycle increases under load if they are the original ones...
To Engine Ticking Under Load
