trans. main seal
Old Mar 10, 2012 | 09:40 AM
geogolf's Avatar
geogolf
Default trans. main seal
anyone know for sure if skf 12975 and gm part 24228816[old #24207010] are the same seal, skf is 7.00 gm is 40.00 thanks geo. from what I can find they are the same seal 1999 c5 frc
Old Mar 10, 2012 | 10:09 AM
lucky131969's Avatar
lucky131969
SKF has a great website. It takes about 2 minutes to register, then everything is a mouse click away. You will be able to confirm that way.
http://webtools.skf.com/Sealfinder/welcomePage.jsp
Old Mar 10, 2012 | 10:23 AM
geogolf's Avatar
geogolf
Default seal
thanks lucky I am 99% sure its the same seal just would like to comfirm
Old Mar 10, 2012 | 11:43 AM
harrison520's Avatar
harrison520
This maybe the gasket causing my ATF leak...01' ?
To trans. main seal
