E3 spark plug cleaned up over NGK 55s
Old Mar 11, 2012 | 01:03 AM
Harry Marsh's Avatar
Harry Marsh
Default E3 spark plug cleaned up over NGK 55s
I have two C5's
Both needed plug changes
One had been recently switched to NGK 55R's when previous owner added cold air intake (just bought this car)
Car idled for crap. E3's were a vast improvement. Smoothed it right out...
Other car had old spark plugs....so no comparison to be seen, there.
Regardless, very happy with these E3 spark plugs. And cheap, too.
Not happy with the NGK 55's (car had an awful stumble to it at idle...plug looked a little hot - thinking predetonation)
Even had a check engine code misfire because of the NGKs
Just a note for others searching...that i liked the E3's
(couldn't find much info when I searched on here)
Old Mar 11, 2012 | 03:02 AM
baxsom's Avatar
baxsom
you are probably the only one then. most people call them snake oil.
Old Mar 11, 2012 | 09:14 AM
hotwheels57's Avatar
hotwheels57
Don't worry about what other people think of E3 plugs (or any other product). Most have probably never personally used them anyway.
You've got positive personal experience to base your opinion...
Old Mar 11, 2012 | 09:58 AM
oldvettedrvr's Avatar
oldvettedrvr
Oldtimer
I took E3's OUT of my 98 because of a stumble at idle. Replaced them with NKG's.
If you have good luck with them...great..your money,your car !!!
Old Mar 11, 2012 | 10:12 AM
Harry Marsh
Did you go with the NGK 54 or 55?
I think the 55 is too hot for a stock car (my stock cars, at least)
54 might have been a better choice
I didn't know of the bad press on the E3
My local mechanics liking them
Old Mar 11, 2012 | 12:42 PM
rebelheart's Avatar
rebelheart
We have had to remove multible sets of E3's in customers cars to rid them of misfire codes and check engine lights.I wouldnt use them.
Old Mar 11, 2012 | 06:40 PM
oldvettedrvr
Oldtimer
I used the 55's. Have not pulled any to have a look but have had them in for about 4k miles and so far so good.
Old Mar 11, 2012 | 07:05 PM
imavettegirl's Avatar
imavettegirl
any vehicle i ever tried multiple prong plugs in they ran like crap and ended up being a waste of money.
Old Mar 12, 2012 | 09:47 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
NGK 55's are stock heat range
NGK TR6's are 1 step colder
Old Mar 12, 2012 | 01:41 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
My opinion if an engine ran better with E-3's then most likely the car would have ran better with ANY spark plug change --It just needed plugs period---
25 years of racing ( both drag and endurance) most all racers seem to use NGK--as they are easy to read and burn more evenly--Even in Nascar where Champion is major sponsor--If you loook closely they all use NGK !! and we used to get the champions for FREE---
IMHO----
Old Mar 12, 2012 | 08:44 PM
Harry Marsh
IMHO----
That is exactly what I thinking and wondering. If the spark plug change helped, but could help more
The NGK55's looked pretty new.
I used to run a turbo car at the track....I know my spark plugs. I know that NGK's are good plugs.
But, sometimes...you find your application between their heat ranges and a different plug can sometimes fit better
These NGK 55's looked a little hot and lean. I assumed the previous owner went to a hotter plug...didn't know 55's were stock
No misfire codes with the e3's. Smooth idle and not complaining...but wondering if a different plug would improve even more
I see that the e3's are not gappable. Are the people that don't like them...the people with not so stock cars? That need a tighter gap? Bigger cams, nitrous or forced air?
For a stock car, might the E3 work pretty well? (as advertised?)
I'm interested in thoughts. And already thinking about a different plug swap (iridium ac delcos)
Old Mar 13, 2012 | 12:03 PM
rebelheart's Avatar
rebelheart
I play around on a Sun ditributor machine and have found that no matter how many prongs a spark plug sports,the spark only jumps ONE gap.
Old Mar 13, 2012 | 08:38 PM
lionelhutz's Avatar
lionelhutz
What was the 55 plug gap? I've read a service bulletin here that GM moved to a 0.040" gap from the early cars with 0.060" gap and the larger gap sometimes caused misfires and rough idle. I believe all the C6's run the smaller gap too. There's a different plug P/N that come pre-gapped with the smaller gap.
Old Mar 14, 2012 | 05:05 AM
vettenuts's Avatar
vettenuts
TR5 has the smaller gap. The second "5" denotes the gap specification. NGK used to have a really nice catalog you could download that explains their part numbers and gave the specs on each plug. The web site also provides the specs. I went with TR6 with the last H/C setup as NGK also recommends you drop one heat range for each increase in 100 hp.
Old Mar 14, 2012 | 08:52 AM
81c3's Avatar
81c3
Maybe you (OP) had a crack in one of the ceramic insulators causing the stumble from the NGK's. If your not looking hard you can miss one. Over tightening the plug is usually the cause. Not trying to tell you that you dont know what youre doing.... just adding from my own experiences.
Old Mar 14, 2012 | 08:59 AM
fastyellowss's Avatar
fastyellowss
Have you ever seen how these warehouse, and delivery guys handle the pacages they are delivering. They just throw the stuff around. It's not an impossibility to get a plug or two with a non visible crack in the insulator.
Old Mar 14, 2012 | 11:38 AM
Harry Marsh
I appreciate the thoughts. If I should have kept with the NGK's, i'm interested to know it
TR5 instead of the TR55? TR5 has the smaller gap, while the TR55 has the larger gap?
The gap looked to be about .060" I never mentioned...but remember thinking it looked a bit big
The problems (miss at idle) with the NGK were definitely spark plug related. None were fouled. But, a crack could be the culprit. the E3's cleaned it up, but you have me wondering if a new set of NGKs would make a further beneficial difference
Old Mar 15, 2012 | 05:34 AM
vettenuts's Avatar
vettenuts
From NGK:
TR55
V-Power Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Solid Terminal Nut, Projected Tip, V-Power (V-Grooved Centere Electrode), .060" (1.52mm) Gap, Heat Range 5
TR5
V-Power Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Removable Terminal Nut, Projected Tip, V-Power (V-Grooved Centere Electrode), .040" (1.02mm) Gap, Heat Range 5
Here is the NGK numbering system: Link to NGK Numbering System
Old Dec 9, 2014 | 09:53 PM
ThePatriot's Avatar
ThePatriot
Default E3 Rough idle and dies after rev
Originally Posted by vettenuts
From NGK:
TR55
I really want the E3's to work in my applications but so far no such luck. I put them in my mildly built Hayabusa (180hp motorcycle) and it hardly ran so I had to go back to NGK's.
I just put them in my C5 running LPE CNC Heads, hot cam, etc. running NGK R TR55 gapped at .060. It's a 520+ HP at the crank motor that I have tuned to run rich at idle (actually too rich). The E3 immediately caused poor idle and revving caused the engine to die every time rather than returning to idle. It just doesn't want to run with these plugs.
Anyone have any ideas? I hate to scrap these and call them junk for performance applications but just in over my head on this one.
Thoughts?
To E3 spark plug cleaned up over NGK 55s
