re: Headers
Old May 16, 2002 | 12:32 PM
Mike Siska's Avatar
Mike Siska
Default re: Headers
A friend of mine put Belanger headers on his Z06. He trailers it to the races now. However, when he tools around suburbia in all kinds of traffic, he says the heat coming from the transmission tunnel where your right leg sits is really unbearable. With the stock exhaust and pupcats, he said this issue didn't exist.
My question is: Do LTheaders (of any type) cause this problem?
Old May 16, 2002 | 12:39 PM
jpas's Avatar
jpas
Default Re: Headers (Mike Siska)
Hey Mike,
I have the LGM long tubes with the race merge collectors. I have no heat issues in the tunnel area. Is he running the stock cats? I have no cats on my setup.
Old May 16, 2002 | 12:43 PM
Mike Siska's Avatar
Mike Siska
Default Re: Headers (jpas)
jpas... he has Belanger headers, stock cats, corsa xpipe and corsa daytona oval exhaust. He was thinking of getting dynamat and putting that on.
Old May 16, 2002 | 01:11 PM
Patches's Avatar
Patches
I have the FLP's with the hi-flow cats and haven't noticed any increase in heat from the stock setup. Sounds like Dynomat or a similar product is in order for your friend. :yesnod:
Old May 16, 2002 | 02:03 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Headers (Patches)
I noticed no increase in tunnel temps when I went to my TTS Long Tubes.
Old May 16, 2002 | 06:28 PM
cjones's Avatar
cjones
Default Re: Headers (MattG)
Get some Dynamat sound deadening. It has an aluminum foil finish on one side and really cut down on the heat under the arm rest in my C5.
Old May 16, 2002 | 10:47 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
koolmat, http://www.koolmat.com/corvette.shtml makes a heat blanket for the torque tunnel.
[Modified by kewlbrz, 8:50 PM 5/16/2002]
Old May 16, 2002 | 11:02 PM
JWSchmidt3's Avatar
JWSchmidt3
So did I, and it was too hot in the cabin of my vert going 70+ mph down the highway and 34 degrees outside. Got the KoolMat, but the car didn't run long enough for me to determine any difference. That area is already hot on stock cars, and LT headers without CATS make it even hotter. Keep in mind, the stock CATS have individual heat shields on them, so figure at least that much heat when you lose them, plus add the headers. It all adds up. :cheers:
Old May 16, 2002 | 11:05 PM
movinup's Avatar
movinup
Mike,
I also have jet coated LGM headers and my tunnel is
much cooler than it was before the headers. The lack
of the precats is probley the reason it is cooler.
Old May 16, 2002 | 11:08 PM
kewlbrz's Avatar
kewlbrz
Default Re: Headers (JWSchmidt3)
JW I would of assumed loosing the cats would make it less hot under there since cats are designed to run hot and burn things up.
Old May 16, 2002 | 11:15 PM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: Headers (kewlbrz)
Wasn't in my case, and the headers just made it hotter. But that tunnel has always run hotter on my vert (2000) than on my coupe (1998), and my coupe has headers with CATS. Maybe it's just a case by case situation. Still worth the KoolMat probably IMO.
Old May 16, 2002 | 11:16 PM
Z06 Quin's Avatar
Z06 Quin
Headers on the coupe huh??;)
Old May 16, 2002 | 11:36 PM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: Headers (PoBoy Racer)
Yup, bought it with them on already. So what's your point?? :confused: :p: :hat
Old May 17, 2002 | 12:51 AM
Paradigm's Avatar
Paradigm
Probably looking for a recommendation. :cheers:
Old May 17, 2002 | 11:09 AM
johnnyC5's Avatar
johnnyC5
my TTS Long TUbe headers are on there way.... and hope that they don't generate any more heat than the stock setup.
i can't see why that "koolmat" or "heamaster" shiled is soooo expensive
aren't there any other alternatives with respect to other types of matting?
Old May 17, 2002 | 12:30 PM
dbvettez06's Avatar
dbvettez06
No problems here with heat :)
To re: Headers
