shifter rattle
Old Mar 13, 2012 | 04:33 PM
donnie brooks's Avatar
donnie brooks
Default shifter rattle
I noticed a rattle recently ,it seems to be coming from the shifter area,my car has the B&M shitfter.Well I decided to investigate the shifter area and did find that the two bushings that hold the two bolts are falling apart,it is the two bushings that has the oval shaped metal part in the middle and holds the assembly to the car.I am hoping that these parts can be ordered without having to buy the entire shifter assembly,any help would be appreciated.
Old Mar 13, 2012 | 04:40 PM
hotwheels57's Avatar
hotwheels57
They're not available separately from GM unless something has changed recently. There is a vendor here who sells reproduction rubber bushings (approx. $20)...
http://forums.corvetteforum.com/c6-p...-kits-jwm.html
Try this member (MEZ) for replacement rubber bushings...
http://forums.corvetteforum.com/c6-t...-solution.html
You might get lucky and find a pair of Z06 metal bushings and never have to replace them again. Put a WTB ad in the classifieds.
Another option is polymer bushings from ZIP-CORVETTE...
http://forums.corvetteforum.com/c6-t...-bushings.html
Old Mar 13, 2012 | 05:44 PM
freeman4ever's Avatar
freeman4ever
While replacement bushings may solve your problem, you may also want to consider THE FERNCO MOD (below) in addition - as it is cheap, easy, and...yeah...
Originally Posted by Patches
For aftermarket shifters, I have always used a Fernco rubber pipe cap tho quell the vibrations that can happen when you install a Hurst, Ripper or MGW shifter. My aftermarket shifters have never suffered from those types of vibrations since I installed one of these. A forum member posted this here long ago so I don't remember who to give credit to. The cap can be bought at Lowe's/HD.
Here's my current MGW
With the Fernco cap
The cap - I use the 1-1/2" version. I used this 2" version when I tried the C6 shifter.
Old Mar 13, 2012 | 05:52 PM
freeman4ever
Pay particular attention to this:
Old Mar 14, 2012 | 10:46 AM
MStrahan's Avatar
MStrahan
I'm not sure if that will cure your problem. Is the rattle all the time or just with hard acceleration? If it's the later, it's the shifter. Sell it and buy a MGW. That's exactly what I had to do to cure the rattle.
Good luck.
To shifter rattle
