2000 C5 Coupe Exhaust
Old Mar 15, 2012 | 02:56 PM
rolando.reyes's Avatar
rolando.reyes
Cruising
Default 2000 C5 Coupe Exhaust
I am thinking of replacing my whole exhaust system on my C5 2000 coupe from the manifolds to the cat backs with a 2002 Z06 exhaust system. Will this be a straight bolt on swap? Has anyone done this?
Old Mar 15, 2012 | 04:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
THE ANSWER IS YES & NO
Yes it will bolt right up. The NO part comes in on the A.I.R. Piping on the passengers side.
The A.I.R tube mounting flange is moved to a different location further forward than where yours is bolted to. You can get around the issue by cutting the tube, doing a little bending and connecting it with a piece of high temp synthetic rubber hose.
You will have to purchase a 2001 + oil dip stick and tube as it also bolts up in a different location on the Block vise the manifold. You can see the bolt hole on the passengers side of the head.
Heres a crappy picture of where the oil dip stick is on the 02 Z. Much further forward.
Order the tube and dipstick and gaskets from Gene Culley
www.gmpartshouse.com
You will also need the 2001 + OEM steel header gaskets. Yours will NOT work!
Hope this helps.
Bill
Old Mar 16, 2012 | 11:45 PM
C5Enthusiast's Avatar
C5Enthusiast
Appreciate this info....Exactly what I'm working on, too.
Patrick
To 2000 C5 Coupe Exhaust
