c5 overdrive slipping
Old Mar 16, 2012 | 09:43 PM
gc258's Avatar
gc258
7th Gear
Default c5 overdrive slipping
I was wondering if anybody else has this issue and can i fix it myself?I drive at high speeds often,lately the trans has been slipping only in overdrive at high speeds,shifts thru all other gears normal.650hp on stock auto c5 trans.A friend in germany told me the pads heat up?? and need to be replaced,apparently all auto trans run at high speeds have this issue in germany.Anyone hear of this?
Old Mar 16, 2012 | 09:55 PM
RonSSNova's Avatar
RonSSNova
What year?
Check codes yet?
Look for P1870. Transmission component slipping.
Was an issue on 2000 year and earlier. It was an issue with the valve body valve that controls torque converter lockup.
Also, you have a ton of power for a stock trans.
Old Mar 18, 2012 | 01:23 PM
gc258's Avatar
gc258
7th Gear
Its a 1999 no trouble codes,to my surprise the trans has held up to this horsepower for 2 years and I've been hard on it at the track.I've priced some re manufactured trans online,thats the direction I'm gonna go.I can pick 1 up for $1300 which surprises the hell out of me.Thanks for the input.
To c5 overdrive slipping
