coil mtg. bracket identification
Old May 16, 2002 | 07:34 PM
arnold's Avatar
arnold
Default coil mtg. bracket identification
I'm adapting the LS1 coils to an earlier engine. The coils are the same,
however, the coil mounting brkt. for 99-00 is a different part # than
the 01-02 brkt. Does anyone know the difference betweenthe two
brackets? BTW, the corresponding mtg. studs also carry a different #.
Old May 16, 2002 | 10:42 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: coil mtg. bracket identification (arnold)
97-98 have perimeter valve cover bolt patterns which effect the coil brackets for those years. 00+ have center valve cover bolts, thus the coil bracket mounting holes are a little different giving a different part number.
