Turn signals don't always work
Mar 18, 2012 | 02:40 PM
I'm thinking it's something to do with the hazard switch.
Reason being is that when I signal, it doesn't always flash, no sound, either.
I tap on the dash right above the hazard switch and it works.
I have the dash torn off now and it's something I want to address.
Should I just replace the hazard switch?
Mar 18, 2012 | 02:49 PM
I had the same problem and it was the hazard switch, Very cheap to replace so I would go with that.
Apr 11, 2012 | 10:33 PM
1st Gear
4-way flasher module
It's the 4-way flasher module located behind (and part of) the 4-way hazard switch. I got mine at gmparts.com for about 30 bucks about 5 years ago. I finally got around to replacing it. Wasn't easy but it works fine. You can get to it with just the radio removed. Write me if you need more help.
Apr 11, 2012 | 11:17 PM
The GM part is crap as this is a common problem. Fix it with the
JW Motoring Harness like I did and never have the problem again.
Apr 11, 2012 | 11:35 PM
Apr 11, 2012 | 11:38 PM
Works great!
Apr 12, 2012 | 11:59 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Thanks guys. We have the harnesses in stock which is rare
Apr 12, 2012 | 01:41 PM
Quote:
Originally Posted by
Edmond
I had the same issue about 3 years ago. tore the dash open,replaced the hazard switch behind the center AC vent. No issues since.
Apr 12, 2012 | 01:45 PM
JW@JWMotoring.com
Thanks for a great product!
Btw, since it hasn't been mentioned, replacing the harness is waay easier too
Apr 12, 2012 | 03:53 PM
5 minute job tops.
arizona ,
blinkers ,
c3 ,
corvete ,
corvette ,
dont ,
hazard ,
makes ,
signals ,
switch ,
turn ,
work
