C5 e-brake interchange with 2009+ CTS-V
I am a bit of an oddball here. I am installing 2009+ CTS-V brakes front and rear onto my '87 Camaro. This is my dad's CF account. I want to retain the factory CTS-V e-brake. There are several places that make conversion kits to run rear C5 brakes + e-brake on a 10/12 bolt flanged solid axle. Since you guys are the C5 experts, I am trying to find out if the CTS-V e-brake assembly and caliper brackets interchange with the C5? In other words, if I have brackets to bolt up C5 brakes, can I bolt up the V brakes as well?
The CTS-V seems to have the same 3 bolt axle flange that the C5/C6 and new Camaro has.
Adapter brakcets for C5 brakes on a solid axle 10/12 bolt.
A diagram of the V e-brake assembly.
Thanks,
John
