LS1 Edit: Where to plug into Car
Old Mar 18, 2012 | 08:27 PM
JMLS's Avatar
JMLS
Default LS1 Edit: Where to plug into Car
First of all, Im new to the forum! Glad to finally join rather than being a goon that just read posts.
Secondly, I know some basics on how to program using LS edit. I really just looking to lean out my car. Its running way to rich. I have K&N air filter, Z06 intake/intake manifold. Long tube headers and borla exhaust with not cats. I also have 3.42 gears. The car has been professionally tuned before with my locked copy of LS edit but the car is running way to rich.
I know what to do once in LS edit but I cant for the life of me find on any forum or and tutorial where the plug in is for the cables! I know its either under the glove box or under the driver side below the steering wheel. I dont feel like digging into the car too much until I know the actual location of the plug in.
Can someone point me to the location via picture or a link to a site that does?
I would greatly appreciate it!
Old Mar 18, 2012 | 09:00 PM
Paul Wood's Avatar
Paul Wood
I believe that the only way you can access the system is through the OBDII port located under the steering column. You may have a "window valet" plugged into the port that is making it hard to find. Good Luck.
Old Mar 18, 2012 | 09:44 PM
dougbfresh's Avatar
dougbfresh
If you can't figure out the ONLY place to plug it in, better not fool with it. Lean out the car too much and you'll have melted pistons-leave it to the pros.
Old Mar 18, 2012 | 11:18 PM
lionelhutz's Avatar
lionelhutz
Stick you head down between your knees and look up...
Old Mar 18, 2012 | 11:38 PM
sfc rick's Avatar
sfc rick
Yep it's there!
Old Mar 19, 2012 | 04:40 AM
JMLS's Avatar
JMLS
As far as letting a "professional" do the job, HA! The last "profesional" I let work on my car effed things up so bad that I had him immediately remove most of the stuff he put on. I'm not doing anything radical, just minor adjustments to the fuel map. The thing backfires like crazy and Im going through spark plugs like a fat kid and candy. If anything I'm probably just going to download a pre-made mapping.
Thanks. That's where I figured it was. I actually found it after I posted this. There is literally no lighting in my apt's garage so it was digging in the dark.
Thats a good one man. I remember my first joke. But hey, if you get off to people stickin stuff up there a** Im not going to judge you. Maybe you should stick to a website that better suits your interests rather than trolling the tech forums.
Old Mar 19, 2012 | 12:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You probably need to do an AUTO VE tune. If your running very rich, monitor your fuel trims. If there significantly positive, that’s your issue.
Adjust your Volumemetric Efficiency (VE) Table and then your MAF tables. An Auto VE tune requires the use of a wide band O2 monitor!!
I know that EFI Live has an AUTO VE tuning function. I do not know if LS1 Edit has that feature.
You’re going to need a WIDE BAND to be able to make any logical and meaningful adjustments. If you don’t have a wide band,,, I STRONGLY recommend NOT fooling with any tables that alter fueling!
Especially the Power Enrichment tables!!
BC
Old Mar 19, 2012 | 09:10 PM
lionelhutz's Avatar
lionelhutz
Not sure how you sit in your car, but my knees are under the column, not under my ***.
Apparently, you are incapable of understanding a sarcastic instruction...
Old Mar 21, 2012 | 12:19 PM
JMLS's Avatar
JMLS
You never said anything about sitting in a car. As far as I know you were just making a unnecessary smart a** remark.
Old Mar 21, 2012 | 10:08 PM
lionelhutz's Avatar
lionelhutz
Why the fck would you try to plug in the cable if you weren't in the car?
Old Mar 21, 2012 | 10:25 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Damn...
I thought this BICKERING would have played its self out by now.
Can SOMEONE please be MAN enough to suck it up and just continue on with the original question or just leave the crap behind.
This is NOT going to resolve your issue and questions!
Bill
To LS1 Edit: Where to plug into Car
