My fair warning for C5 kook 1-7/8" headers installation
Jimbo
Chrysler also chose ARH to design/build the header for the Viper ACX and Challenger Drag Pack
Ford also, FR500 a few years ago
Hand built in the USA
OP, sorry you had so much trouble. Several extra sets of hands help with any LT header install.
Both valve covers
Spark plugs and. Wires
Alternator and alternator bracket
Tempature censor from driver side head unless you want to break it
Remove entire steering shaft
Disconnect power steering resivor and drain oil or big mess will follow
Remove oil filter and if you have an oil block for an oil cooler
Aftermarket fuel rail
Starter
Lower portion of the bell housing
Disconnect sway bar
Disconnect both upper a arms
Disconnect engine rubber mounts
Drop engine cradle
On my C3, the only thing I removed was the clutch linkage.
I can imagine how brutal it would be with LS1/6 engine, however since i love challenge i might install these on a C5 with c5 engine.
LTs are illegal on C5s here in Cali but many guys play Russian Roulette by installing them and then hoping that they don't get noticed. The same thing happens with Vararam intakes; I would hate to have to replace both, every two years.
These headers will not slide in by any means unless you remove parts
This is my story.
I have to remove the following parts to get the headers to slide in.
The list of removed parts:
Both coil packs
Both valve covers
Starter
Disconnect sway bar
Drop engine cradle
You will have to replenish the engine oil, coolant, oil filter, power steering oil, and in my case the brake oil because I had to remove the line lock.
Driver side came in from the top and the passenger from the bottom.
All was possible from a combination of dropping the cradle and swinging it out the way and lifting the engine and rocking it side to side with a ratchet strap.
To the guy that designed the instructions and the headers FUC$ you.
Would I ever install a set again, yes I would because I know what is involved in the installation.
I took around three days to install them because I worked on the car here and there. I did have to walk away many times because I was so pissed at the fact that the more parts I took off the car the headers would not go in.
Roger
looks like the swear jar might get full tonight (if i had a swear jar that is)
I had a shop do mine for 500 that included install and dyno tune after. I couldn't pass that up and he said it was the easiest set he has ever installed on a vette. Almost 40hp gain you can't beat that
