01-04 tpms will not program
Old Mar 20, 2012 | 08:53 PM
steveovette's Avatar
steveovette
Default 01-04 tpms will not program
Finally updated tire monitors, fobs, and receiver to 01-04 parts on my 1999 coupe. Key fobs program fine but I cannot get the dic to move past the fobs to tire monitor with the option button. System worked fine with the old monitors.
Any ideas?
Old Mar 21, 2012 | 01:31 AM
papagofast's Avatar
papagofast
I'm having the very same problem. Has anybody gotten back to you with an answer?
Old Mar 21, 2012 | 08:19 AM
steveovette
Nope. No answer yet.
Old Mar 21, 2012 | 04:00 PM
papagofast's Avatar
papagofast
Got my TPMS problem solved this morning. Go to my thread to see how it was solved. You may be having the same issues.
Old Mar 21, 2012 | 06:05 PM
steveovette
Ok thanks. I guess I should maybe take it for a drive to see if they "wake up". I can't understand why I can't get to the monitor option. Before the switch over the system was working. I installed the tire sensors first so of course the old receiver would not recognize them. Just showed zero on the dic and I just cleared it out while driving. Since the change over of the fobs and receiver I have not driven the car. I actually have the J tool (kent Moore magnet) to activate them once I get the dic to work.
Old Mar 22, 2012 | 06:57 PM
steveovette
Ok guys I've tried everything I can think of to get past the program fobs to tire monitor option. I even pulled the power from the bcm and cluster hoping they would reset.
Is it possible that the receiver is from a ZO6 and different than none ZO6 01-04?
As stated before fobs program fine, but cannot get the cluster to the next step, tire monitor.
Old Mar 22, 2012 | 10:08 PM
steveovette
Thanks for your help 8VETTE7. I did check the BCM for corrosion and all connections. Alls ok. You are correct in understanding my problem. Just to clarify I had my stock wagon wheels on last week with the original setup and all was well. I reinstalled my a/m wheels with the new sensors this week and the dic was working showing zero pressures due to the mismatched receiver etc. I installed the new stuff and proceded to program with the as mentioned results. The only thing I left out was I had the PCM tuned in the mean time. I didn't mention it as I know the system is controlled by the BCM not the PCM.
To 01-04 tpms will not program
