Clutch is out!
The box from ECS just arrived today, so now all I have left is:
- Take the new FW/PP into the shop to get it match balanced. My old one has weights added...
- Remove the pilot bearing and install the new one.
- Install the new slave, master, and bleeder
- Install the FW/PP/clutch
- Reassemble the driveline
- Reinstall the driver's side header and the exhaust
Just went with the LS6 clutch since my car only makes 350 rwhp and I don't have plans to add massive power in the future.
Probably another 10 hours left, working as slowly as I am. The only real issue I have is that I failed to realize that I didn't jack the rear of the car up high enough to fully remove the driveline. So I had to seperate the torque tube from the transmission while under the car... which was less fun.
Also, I opted to seperate the rear brake lines above the transmission rather than pull the drive shafts out of the diff. Seems to have been the easier choice.
You'll need a transmission jack (Harbor Freight- $110) and at least two more jacks.
You will have people tell you this is unnecessary, overkill, or just plain wrong to do. Don't listen to them. This is your best way to match the final fine tune balance done at final assembly.
Good luck with the completion of your project.
On a side note, I found a pair of snap-ring pliers to ge tthe C clip off the torque tube. Turns out the rubber couplers are indeed toast and needed to be replaced. Glad ECS talked me into buying them, but man are they spendy ($100 each).
I bloody near broke my finger, too.
New bearing is in, new clutch/PP/FW are in. Replaced the TT couplers. Twice. Do yourself a favor and pay attention ot the direction of the arrows on the couplers. I guess it matters?
Installing the TT onto the transmission was easy. Getting the entire assembly into the engine was a lot harder. Turns out the "measure the height of the transmission before you disassemble it..." plan is fatally flawed. See, the TT is 6' long. If you measure the transmisison height, a 1mm difference (or error in measuring) will result in a 6mm difference at the end of the TT. IE, worthless. I ended up eyeballing it until the end of the driveshaft was aligned and touching the clutch, then using a pair of electronic calipers to measure the gap between the bellhousing and the TT. Up with one jack, down with another jack, and finally I got the gap perfect.
Using a C-clamp, I was still unable to get the driveshaft splines to align with the clutch disc. Eventually I ended up marking the edge of the cluth disc hub where the splines were. Since I can see the input shaft, just turn the FW until the mark aligns with a groove and it worked very well.
Tonight it's time to bolt everythign back together. Overall, I think I'm loking at about 20 hours on jackstands to do the whole job by myself.
Sounds as though your doing a great job
Would have any of the below processes, could have benifitted in doing this job?
Possibly a little butane torch onto the p/beaaring would have helped on removal?
Use an actual steel input, splined shaft for p/plate clutch disc allignment.?
Allignment measurements, taken prior to removal & install . Using a a laser level.
Measurement at the front / bottom side of t/tube, & rear / bottom side of t/tube, prior to removal & match those measurements when doing the reinstall. ?
Where were you able to find the large snap ring pliers?
What t/tube rubbers did you go with?
Thanks for taking the time & effort for sharing, your process of the change out.
Thanks Umrswimr
The alignment tool worked just fine to ensure the clutch disc and the pilot were aligned you while you torque down the PP. The issue was getting the input shaft aligned with the FW assembly in three dimensions (plus getting the splines aligned). A real input shaft wouldn't make any difference here.
Would a laser level work? Possibly, but I'm not sure I would hassle too much with it. My rear would shift slightly on the transmission jack from all the pulling, pushing, tipping, etc. I'm not sure I could get it back to the precise location with measurements alone. Using the calipers, I was able to precisely ensure the bellhousing and TT were aligned and straight. Once I figured out what I needed to do it only took maybe 15 minutes. Of course, it took 45 minutes to realize I needed to abandon my previous plan.
The snap ring pliers came from Harbor Freight. They sell a large set that includes seperate internal and external ones with replacable tips. They are cheaply made, but they got the job done.
For couplers I bought the German ones from ECS at the same time as I bought the LS6 clutch. They are $100 each, but if I can avoid doing this work again for another 10 years, it's worth it. Seriously- anything that requires this much effort is not worth saving a few dollars.
Only a few minor inconveinces this time around:
1) Installing the LG headers sucks. It'll fit, but not by much. And getting it bolted to the heads with one person is really not fun.
2) Resintalling the clutch master is a tight fit, but the clutch bleeder is a Godsend. MUCH easier now to bleed this thing out.
3) I chose to remove the alternator to make R&R of the driver's side header easier. I then failed to reinstall the belt prior to my test drive. Luckily I didn't go far.
Tonight it's back up on jackstands to check all the exhaust bolts and make sure the O2 sensor wires are tucked away from the headers. It's REAL tight up there so I'm not sure how well I routed it all. Otherwise the clutch holds strong and no issues to report!
Total time: 25 hours by myself. This includes rebuilding the torque tube.
http://www.smokinvette.com/corvette/...a-c5-corvette/
