Help!! Passenger side Window Issues
Old Mar 22, 2012 | 08:40 AM
biglane's Avatar
biglane
Cruising
Default Help!! Passenger side Window Issues
I have replaced the regulator, but I am still getting the clicking sound. What should I do next? What volts should the motor recieve? I am only getting 4.5 volts from the plug that goes into the motor.
Old Mar 22, 2012 | 09:12 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Most likely you have a failed relay inside of the door control module. Here's a link with some information. Yes, you can replace the relay.
http://www.ronjpics.com/Corvettestuff.htm#DCM
Old Mar 22, 2012 | 01:21 PM
biglane's Avatar
biglane
Cruising
Thanks dgrant3830.
Is there anyone in Denver that has experience with changing the relies in the DCM? I am afraid I will screw it up.
Old Mar 22, 2012 | 01:45 PM
SaberD's Avatar
SaberD
There was a forum vendor that did repair service on these. I forgot who it was. You can just mail them your module, and they will put new relays in for you.
Old Mar 22, 2012 | 02:24 PM
biglane's Avatar
biglane
Cruising
I just talked to the StealerShip, and they said if I replace the Passenger DCM, I have to replace both of them. Is that true?
Old Mar 22, 2012 | 04:12 PM
dgrant3830's Avatar
dgrant3830
Nope, not true as far as I'm aware of.
Old Mar 22, 2012 | 04:48 PM
biglane's Avatar
biglane
Cruising
I found a shop in Denver that will do the soldering for me, not I just need to search the Forums to order the correct Relays!! Thanks Everyone.
Old Mar 22, 2012 | 05:18 PM
biglane's Avatar
biglane
Cruising
If you need to order the relays, you can go to www.alliedelec.com, and the stock # is 70158534 part number # JSM1-12V-5.
Old Mar 22, 2012 | 05:19 PM
biglane's Avatar
biglane
Cruising
Btw, the Stealership told me $500 each for the DCM. And they would give me the part number.
Old Mar 22, 2012 | 07:15 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Regulator fixed mine, but I did have to change the relays for door lock and unlock. Bought mine from Digikey. $1.72 each. $4 vs $400. It was a pain to trim off silicone coating and unsolder, but was worth the savings.
Old Mar 30, 2012 | 09:40 PM
zo659's Avatar
zo659
Same deal here but a easy fix took about an hour.
To Help!! Passenger side Window Issues
