Losing Spark
Picked up our 2002 Roadster at the end of last year .... it had a slight flutter with medium amount to throttle increase ... started the investigation almost immediately ..... starting with cleaning the sensor at the intake ..... then checking all of the grounding points ..... including the coil grounds on the head ..... changed the fuel filter .... plugs and wires ..... including a couple of bottles of Injector cleaner (Techron) ..... all with no gain or change of any kind ....
Seems to be getting more apparent with time .... and get worse with the increase in engine temp.
Currently at idle .. in gear (auto) the drop out is quite noticeable ... again more so as the engine warms up.
We had our local LS tuning guru plug in ... and reported seeing spark drop out .... and all over the map ..... can happen on either bank ... and cylinder .... one time it will be in #1 ... then #7 ... then #4. Not consistent in time .... nor any particular pattern ....
There is no noise ... other then a bit of popping at WOT .... again inconsistent .... oh yeah .... and no codes !!
So now where to go from here ..... thoughts ?????
I will be substituting all of my fuel injectors next week to see if perhaps they were affected by the vehicle having very little use for 5 months. It was at the shop and moved routinely, but on reserve fuel the entire time. I did find a very restricted fuel filter upon replacement and perhaps this contributed to the problem. If the problem persists after this I will be looking to catalytic converters as possible issues related to the O2 sensors. Real-time analytical scope indicates miss among the cylinders, no other codes come up. The cats are stock and will remain so.
I will inform you if I have success with the above or am fortunate enough to find another cause. Best of luck...
A1
I highly doubt that ALL eight fuel injectors could fail all at once and cause the car to die. If you measure the injector COIL RESISTANCE and there all with in spec, ther most likely NOT the issue.
Here are the secondary ignition schematics just for reference:
If you examine the schematics above, look at everything that is COMMON to all the of the coils. You will see that it is Power and Ground.
Always check and make sure that the grounds are in good condition and properly connected to the ground source.
The power HOT in ON and Start, comes from the IGNITION SWITCH. That have a very common problem and should be checked and cleaned if its found to not be proving power to the car when the key is ON. When the car fails, thats the time to have the meter to check the voltage on the coil fuses. (Mini fuse 16 PCM)
Heres a post for you to examine:
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
BC
A1
A1
Thanks a bunch for posting up ......Will continue to update with results .....
Real-time scanning was done on the car since no ECU codes were being displayed. Considerable under-load misfires were present along with random backfire and an apparent enrichening of fuel delivery.
The vehicle had the following repairs/replacements completed:
- MAF sensors thoroughly cleaned
- Alternator output/diodes tested and found acceptable
- Crankshaft Position Sensor replaced
- Camshaft Position Sensor replaced
- Replaced one downstream O2 sensor that read low
- Replaced both upstream O2 sensors
- Switched coilpacks from another properly functioning vehicle
- Replaced previously replaced sparkplugs
With no codes present testing for grounds was completed per recommendations from Bill C. None were found a problem. The vehicle has around 112K miles so changing out the sensors was probably timely. Their service life had been extensive and these changes will only benefit future reliability.
In researching this LS1 problem, many owners have had this similar running condition and difficulty in finding a culprit. One guy in Australia simply fixed the problem by trading in the vehicle! Regardless, this post is too long yet I trust it may prove useful for others if this perplexing problem rears it's head...
A1
