What does a torque converter do?
Old May 17, 2002 | 12:55 PM
01 SR-71's Avatar
01 SR-71
Default What does a torque converter do?
Sorry for probably such a simple stupid question but I really want to understand what they do and what is the difference it the different types. Is a 3000 better than a 2500; what is the difference? I am looking to add 3.42 gears and I was told to add a 3000 converter as well.
Thanks for you patience and answers
:cheers:
Old May 17, 2002 | 01:06 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: What does a torque converter do? (01 SR-71)
Read
http://www.fasttoys.net/yank.html
Old May 17, 2002 | 01:07 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: What does a torque converter do? (wallstAL)
http://www.howstuffworks.com/torque-converter.htm
:cheers:
Old May 19, 2002 | 07:23 PM
Redvette_22's Avatar
Redvette_22
The torque converter simply turns (converts) torque into forward motion. The more torque a particular engine makes, the more stall the same converter will have in different cars.
Old May 19, 2002 | 09:32 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Hi there,
Also, with a higher stall speed converter, you MUST also remember, you develop more heat, through fluid shearing.
This is why a transmission cooler, to supplant the stock cooler, is always recommended.
Besttoyou, c4c5 :crazy:
To What does a torque converter do?
