Exhaust Smell
Old Mar 25, 2012 | 08:47 AM
66 Vette's Avatar
66 Vette
Default Exhaust Smell
I have a 2000 C5 with Corsa exhaust, use Shell 93 octane gas and when the car has fully warmed up has an exhaust smell. When I have been on cruises the car behind me stays back more than normal to not have to smell the exhaust. In your opinion are the Catalytic converters defective and if so is there anything short of changing them to rectify this situation like putting in an additive in the gas? What are your recommendations?
Old Mar 25, 2012 | 08:55 AM
baxsom's Avatar
baxsom
codes?
if your cats are starting to clog your rear 02 sensors will start throwing codes
Old Mar 25, 2012 | 09:31 AM
66 Vette's Avatar
66 Vette
I have no codes come up and the car has approximately 90,000 miles.
Old Mar 25, 2012 | 09:58 AM
baxsom's Avatar
baxsom
i would still say it is the cats. the rear 02 sensors monitor the life of the cats and when the cats start to go wierd stuff starts to happen to the fueling. people are getting rid of theirs all the time to go catless, i would try to get a set of used oem ones off the forum here and try those.
Old Mar 25, 2012 | 10:46 AM
rebelheart's Avatar
rebelheart
Can you tell if it is a fuel smell or an oil or coolant smell?
Old Mar 25, 2012 | 01:43 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Buy a prius
Old Mar 25, 2012 | 03:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Use an inferred measuring device and see if the CATs are working. If not, replace them.
BC
Old Mar 25, 2012 | 06:33 PM
Chilliwack vettes's Avatar
Chilliwack vettes
[QUOTE=66 Vette;1580372137]When I have been on cruises the car behind me stays back more than normal to not have to smell the exhaust. QUOTE]
My '88C4 had similar issues. Once I replaced the cats (which I had to do anyways to pass the Sniffer test) all was well.
Old Mar 26, 2012 | 06:50 AM
66 Vette's Avatar
66 Vette
What do I need to go catless; do I just take out the cats and replace with straight pipe and how does that effect the 02 sensors?
Old Mar 26, 2012 | 11:31 AM
baxsom's Avatar
baxsom
when most people go catless they get long tubes and a H or X pipe that doesnt have them. for example my TSP long tube and X pipe deletes the cats and the bungs for the rear sensors. you have to get the car tuned to turn off the rear sensors or you will get a CEL and the fuel table will have to be readjusted or it will stink because of too much fuel. best bet is to just have them replaced if you dont want to get it tuned at this point.
Old Mar 26, 2012 | 01:51 PM
Turbopower87's Avatar
Turbopower87
Does it smell like rotten eggs or fuel? If it is rotten eggs all the time then your cats are toast and keep in mind it can only get WORSE if you remove the cats all together.
To Exhaust Smell
