Swapped the Diff. this weekend, PICS INSIDE!
Old Mar 26, 2012 | 10:19 AM
LawdoG247's Avatar
LawdoG247
Default Swapped the Diff. this weekend, PICS INSIDE!
I'd like to thank Rick @ rkt56.com and Gene Culley @ gmpartshouse.com for all their help! Also, thanks to my boy James for allowing me to dirty up his garage in the process and thanks to all of you who contribute to this board everyday!
Here's a link to the write-up I reviewed prior to undertaking this job:
http://www.cajundude.com/differential.htm <=== This link mysteriously stopped working overnight! I can't find an alternate.
...enough stalling, ON TO THE PICS!
If you're gonna do it, do it RIGHT!
2 hours in, easier than I thought it would be.
Out of the five nuts/bolts that secure the diff to the tranny, this one was missing! I believe the added flex on the driveline under load caused the pinion & bearing to fail prematurely. Leads me to believe that this rear had been rebuilt before by an IDIOT who thought it would be ok to just leave this out!
3 hours in, good riddance!
4 hours in, didn't have to drop the driveline as far as I thought. I pivoted the housing down and slightly to the right to clear the output shaft. Damaging the firewall was my biggest fear, which is why I was taking my sweet a$$ time during this stage.
All done!
Old Mar 26, 2012 | 02:24 PM
LawdoG247's Avatar
LawdoG247
If this needs to be in the "General" or "z06 Discussion" section, could a mod please move it for me?
Old Mar 26, 2012 | 02:41 PM
bumble-z's Avatar
bumble-z
Staying here in the tech section is just fine.
Nice job by the way. Thanks for taking the time to snap pictures & explain how you did it.
Doesn't it feel good, doing things like this yourself.
No cost for labor but getting paid in knowledge of your car is priceless!
Keep up the good work.
Old Mar 26, 2012 | 02:50 PM
LawdoG247's Avatar
LawdoG247
Thanks! I wish I had taken the time to snap more, but I was in the ZONE and wanted to get it done!
You bet! I've always preferred doing things myself over paying someone I don't know and trusting them to fix it correctly. It's cheaper usually and it allows you to "connect" with your car which is very important in my book!
p.s. I edited the first post to include a link to the write-up I used as guidance.
Old Mar 27, 2012 | 12:02 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
What gear did you start with and what did you finish with? Was it a gear change or just a repair?
Old Mar 27, 2012 | 07:18 AM
LawdoG247's Avatar
LawdoG247
It was just a repair, replaced a bad 3.42 unit with a new one from gmpartshouse.com. I don't plan on "tracking" my car, I just wanted to get that noisy SOB outta there!
Old Mar 27, 2012 | 07:35 AM
Monkey D. Luffy's Avatar
Monkey D. Luffy
nice Job!
Old Mar 27, 2012 | 08:22 AM
Its Bruce's Avatar
Its Bruce
Why did you change the jack position once the cradle was out?
Old Mar 27, 2012 | 08:40 AM
TOPCATHR's Avatar
TOPCATHR
thanks for the pics.......we love when pics are included in the project....
Old Mar 27, 2012 | 09:05 AM
LawdoG247's Avatar
LawdoG247
Notice the little rubber mount in the center of the cradle just above the 2x4? That is all that holds up the ENTIRE rear driveline! I placed a jack underneath the transmission with another 2x4 to support the driveline as I lowered the cradle. There is no crossmember that the transmission rests on.
...unless you're talking about why I changed the smaller jacks position after removing the cradle. I only had two jacks to work with so I took the cradle off the jack and used the small one to assist me in supporting the diff as I slid it off of the output shaft, and also to re-install the new unit.
Same here!
Originally Posted by TheVettePirate
nice Job!
Thank you, sir!
Old Mar 27, 2012 | 06:34 PM
env00's Avatar
env00
Thanks for posting.
A tuner shop once told me that you had to take down the whole drive train to do a rear end change like yours. Good to know they were wrong....
Old Mar 27, 2012 | 06:41 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
Why did you split the upper balljoints instead of unbolting the upper arms?
Old Mar 27, 2012 | 06:55 PM
LawdoG247's Avatar
LawdoG247
It was much easier to remove the nut securing the ball joint & tap the knuckle surrounding the hole to allow the ball joint's threaded shaft to pop out IMHO (hard to visualize through the written word...).
Here's a quick vid of what I'm talking about, you wouldn't be hitting the parts on your Vette this hard because they are forged aluminum but it is a good example. Also, this is a tie-rod end removal, but the same principal applies to ball joints:
http://www.google.com/url?sa=t&sourc...9Wa_1TYk7yhvTg
Hammering the surrounding housing causes the hole to flex and vibrate the tapered shaft out of the hole, EASY! People always fear removing ball joints & tie rod ends because they don't want to damage the boots.
Originally Posted by env00
Thanks for posting.
No problem, glad I could help.
Old Mar 27, 2012 | 07:14 PM
Its Bruce's Avatar
Its Bruce
Unless you're talking about why I changed the smaller jacks position after removing the cradle. I only had two jacks to work with so I took the cradle off the jack and used the small one to assist me in supporting the diff as I slid it off of the output shaft, and also to re-install the new unit.
I was referring to the jack stands, sorry. I've done it a couple times only using the puck locations for the duration of the work, not needing to change the stand location.
Old Mar 27, 2012 | 07:19 PM
LawdoG247's Avatar
LawdoG247
Ah, yea I don't have any pucks. That was the safest place I thought they should go while I lowered the driveline, as that's where the weight of the car rests normally on the cradle anyway!
Old Mar 27, 2012 | 08:13 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Job well done! This is my favorite picture with the bottle! LOL
__________________
Old Mar 27, 2012 | 08:27 PM
LawdoG247's Avatar
LawdoG247
To Swapped the Diff. this weekend, PICS INSIDE!
Old Mar 27, 2012 | 10:06 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Nice job and excellent pictoral write-up!
This will help all not just Z06 owners!
Thanks,Matt
Old Mar 27, 2012 | 10:22 PM
LawdoG247's Avatar
LawdoG247
Thanks,Matt
I'm kicking myself for not getting more "in-depth" with the pics and step descriptions, I was pressed for time and needed to make sure I could get her back together in time to make the 350 mile trip back to Atlanta...aka the break-in period!
Old Mar 28, 2012 | 07:07 AM
madmatt9471
Regardless it is good and simple enough and detailed enough for helping another member
Thanks,Matt
