Headsup Display
Old Nov 15, 2009 | 07:47 PM
larry123's Avatar
larry123
Navigator
Default Headsup Display
My Headsup display has dropped and won't rise when switch is engaged. What might I be looking at to have it repaired? Thanks larry..
Old Nov 15, 2009 | 08:03 PM
dougbfresh's Avatar
dougbfresh
Broken plastic part, do a search, a couple of guys have hacked theirs back together,
Old Nov 15, 2009 | 08:11 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Someone just recently posted a picture of a side plastic cylindrical piece that broke off. Its probably the same with yours. You'll need to pull the dash pad out which isn't as bad as it sounds to get to the HUD.
Old Nov 16, 2009 | 03:29 AM
DeeGee's Avatar
DeeGee
This is the link you need:
http://forums.corvetteforum.com/c5-t...-and-down.html
Old Mar 28, 2012 | 01:04 AM
srkilgo's Avatar
srkilgo
7th Gear
Default Headsup Display 2004
Headsup display will not stayed locked in. I can set options on fuel display, then after the car is turned off and restarted, the "oil" image will display in it's place. Any solutions? Thanks
Old Mar 28, 2012 | 02:13 AM
DeeGee's Avatar
DeeGee
Its worth starting your own thread for a new problem
My guess if your presets are beginning to reset to default is to check your battery. Low battery level is normally the problem.
Old Mar 28, 2012 | 07:45 AM
65GGvert's Avatar
65GGvert
Yeah, you just tacked on a new problem to an over two year old thread with a different problem. Hit new thread when you want to start your own.
But DeeGee is right, your battery is dropping too low when cranking to hold the memory.
To Headsup Display
