fuel gage drops to empty
Old Mar 26, 2012 | 05:18 PM
old guy in a vette's Avatar
old guy in a vette
Default fuel gage drops to empty
I have the usual gas gage trouble. I fill up and drive for 40 minutes and it goes to empty. I tried techron and seafoam several times and it didn't help. My last resort is to change parts. I don't know which tank to pull. If I guess, it will be the other one. The senders are expensive and I don't want to change a functioning one. Anyone have an idea which one tends to go bad?
Old Mar 26, 2012 | 05:38 PM
LoneStarFRC's Avatar
LoneStarFRC
When you "refill" how many gallons are you putting back in? Most times it's the right tank siphon-pump/sender assembly. You also failed to say which year model you have. Makes a BIG difference.
Old Mar 26, 2012 | 10:42 PM
old guy in a vette
98 and I fill it every time.
Old Mar 26, 2012 | 11:52 PM
LoneStarFRC
1. What year model? Answer: '98 OK
2. How many gallons does it take in the tank when you fill it back up after one of these gas gauge experiences?
Btw, if you need to do repairs, you will not need to drop your tank on your '98. It/they can stay where they are.
So how many gallons does it take?
Old Mar 27, 2012 | 02:55 AM
DeeGee's Avatar
DeeGee
There's no way to tell which sender is bad from your symptoms. Assuming the tank is nearly full when it drops to empty (40 mins from full), it could be either sender or even both senders. Some gauge problems give clues as to which one is bad but it's a guess in you case unless you have a code. If the car still has more than a 1/2 tank when it drops to zero I'd replace the drivers side sender first.
Heres a good How To from RJ1AZ which avoids dropping the tanks
http://forums.corvetteforum.com/c5-g...ing-again.html
Old Mar 27, 2012 | 07:32 PM
LoneStarFRC
Maybe he's napping.
To fuel gage drops to empty
