A4 Trans Linkage Adjustment
Old Mar 26, 2012 | 09:08 PM
David Q's Avatar
David Q
Default A4 Trans Linkage Adjustment
Any easy tips for adjusting the shift linkage at the transmission connection. The clip came out, and it seems like it doesn't matter where I plug the clip back in I either cannot get it to shift into low gear or park. Everything was fine, but during a trans swap, after I was done, I had my buddy cycle the shifter through the gears. I couldn't stop him fast enough, the clip got hung up in one of the brackets holding the brake lines causing the clip to pop out. Should I try and set the proper tension in park or low gear? Thanks in advance for any help.
Old Mar 27, 2012 | 01:15 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
There is a precise way to adjust your linkage-The linkage lets your computer know which gear you're in---so the ECM part of the linkage must line up with the mechanical part of the linkage----There are "Marks" on the adjustment plate that you neeed to align--You should be able to find a photo and explanation of the alignment in the manual or somwhere online that has details on a 4L60E trans
