Building forged engine, need some component advice
Old Apr 6, 2012 | 12:19 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Come on, guys. 20 posts and only one covering the recommendations I asked for?
Old Jun 13, 2012 | 06:00 PM
Lloyd Christmas
Update:
Engine will be going back together soon.
Same A&A Vortech V3 kit
New (used) LS1 block
Diamond -2cc pistons with anodized coating
Total Seal rings
Callies Compstar rods (with arp 2000 bolts I assume?)
ARP head bolts
Comp lifters
LS6 cam
TSP oil pump
Rollmaster double roller set
Norris catch can
Gutted cats
Borla Stinger cat back (hmmm, may be a little raspy)
Sound ok?
I'm still going to replace the valvesprings, but not sure what I will use yet. Builder is recommending a set of 918s. I know the pressure would be fine, I would just prefer the insurance of a dual spring. I hear all kinds of stuff about broken 918s, but I don't actually recall any of them failing on stock cams. Picking up another block and getting the pistons coated blew my budget off a bit so I have a little less to throw at other upgrades. Every other component is dead stock. I'm thinking I will increase boost to maybe 9lbs for an even 600hp?
Old Jun 13, 2012 | 11:12 PM
p1bz's Avatar
p1bz
Wow do some of you guys waste money, or what? Mahle forged drop ins, 550. Scat pro-comp rods, 300. melling 10296, 150. King alecular coated bearings 80.00. That is budget and will hold a crapload of power. I have done quite a few on this forum now, and am amazed at how much some guys waste on parts.
Old Jun 14, 2012 | 07:07 AM
Lloyd Christmas
I know, right? Some people waste money on **** like $300 head studs too. What are they thinking?
Old Jun 14, 2012 | 07:56 AM
StatmanRN's Avatar
StatmanRN
I'm planning my own forged build right now so following this as I make my shopping list.
Two things:
1 Cheaper isn't cheaper if it fails and you have to redo it
2 Build stronger than you think you need. You might end up with more boost than planned down the road
Old Jun 15, 2012 | 09:16 PM
Lloyd Christmas
Thanks, Statman. I am an RN as well.
Old Jun 17, 2012 | 01:03 AM
Lloyd Christmas
Anyone have experience with these PRC springs?
http://www.texas-speed.com/p-474-pre...pring-kit.aspx
Old Jun 29, 2012 | 05:44 PM
Lloyd Christmas
I just ordered the PRC .650 spring kit. I'm using an LS6 cam with stock LS1 heads and rockers, comp lifters. I went ahead and ordered longer pushrods. For a basic LS6 cam, stock LS1 head setup, do people usually measure for PR length or just go ahead and put the 7.425 rods in?
Old Jun 29, 2012 | 07:32 PM
p1bz's Avatar
p1bz
Unmilled with stock HG use stock length.
Old Jun 29, 2012 | 09:15 PM
Lloyd Christmas
dammit!
Old Jul 9, 2012 | 10:47 PM
Lloyd Christmas
OK, I don't think I can resist throwing a set of headers in while the engine is out. Hell, I can save almost the whole cost of the headers just in labor. I figure making it easier for all that forced air to get back out is probably a good idea and might lower chamber/EG temps some.
If you guys have a better way to spend the $800 then I'm all ears. Well, I guess I will have to add another $400 for a zo6 catback since headers through Borla Stingers is probably a bit much for me.
Old Jul 9, 2012 | 11:10 PM
p1bz's Avatar
p1bz
If installing headers go ahead and wrap your wires down around the starter are with heat tape. Trust me on this.
Old Jul 9, 2012 | 11:38 PM
  #33
p1bz's Avatar
p1bz
Old Jul 10, 2012 | 06:50 AM
  #34
Lloyd Christmas
OK, I will try to have that done as well. Sounds like you have had some issues with it.
Old Jul 12, 2012 | 04:51 PM
  #35
Lloyd Christmas
I'm planning on using the TSP coated headers. Anyone have experience with them?
