Can you tell the difference....
Old May 17, 2002 | 07:47 PM
Ronin0521's Avatar
Ronin0521
8th Gear
Default Can you tell the difference....
How can you tell the difference between an LS1 and a LS6 by looking at the car. If you dont' have the origional paperwork, how could you check for youself?
Thanks.
Old May 17, 2002 | 09:41 PM
Crushinator's Avatar
Crushinator
Default Re: Can you tell the difference.... (Ronin0521)
The LS6 will have Z06 badging, always be a hardtop, have different wheels and brake vents in front of the rear wheels.
Old May 17, 2002 | 09:50 PM
NoMercy's Avatar
NoMercy
Thanks.
The LS6 motor is only offered in the Z06. By looking at your sig you seem to have a convertible. You also have an LS6? How did you pull that off?? :confused:
Old May 17, 2002 | 09:56 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Can you tell the difference.... (NoMercy)
yea! perspiring minds want to know! :confused:
I hope whoever sold you the car didn't tell you it was an LS6........... :eek:
Old May 18, 2002 | 12:34 AM
2KFRC5's Avatar
2KFRC5
Chad,
First of all, welcome to the Forum.
Check the 8th digit of the VIN of your Vette, G=LS1, S=LS6. Unless someone has made an engine swap.
As previously stated, the LS6 only comes in the Z06 and is the only engine available in the Z.
Thanks.
Old May 18, 2002 | 06:08 AM
Ronin0521's Avatar
Ronin0521
8th Gear
I bought used, and the first owner "blew out" the first engine and replaced with a rebuilt LS6 from a ZO6. But now, being curious, I wanted to know what all was swapped, and if everything was swapped.
I changed the signature until I find out for sure. The car screams, runs great no problems..but I just want to know exactly what is under the hood for sure.
Old May 18, 2002 | 06:14 AM
Ronin0521's Avatar
Ronin0521
8th Gear
Oh, thanks for the welcome and the info! that's why I love this forum. :)
Old May 22, 2002 | 09:00 PM
NoMercy's Avatar
NoMercy
If the previous owner did an engine swap I would get the documentation that supports that. It may make a big difference if you ever decide to sell. From the outside I do not think there is a visible difference between the LS1 and the LS6.
BTW welcome aboard! :cheers:
Old May 22, 2002 | 09:41 PM
aces's Avatar
aces
Seems like the #'s on the block and heads would offer a clue. I don't know where or what to look for though.Maybe someone else will chime in. :cheers:
Old May 22, 2002 | 09:59 PM
NassyVette's Avatar
NassyVette
Default Re: Can you tell the difference.... (aces)
Throw it on a dyno, the numbers will tell you.
To Can you tell the difference....
