Stroker engine question
Old Mar 29, 2012 | 10:47 AM
Levi Walker's Avatar
Levi Walker
Default Stroker engine question
Is there a downside to a stroker engine?
Do you loose low end power or does it produce power throughout the power band?
Is there a way to estimate power gains from a specific CI increase?
Old Mar 29, 2012 | 10:50 AM
JUICED1's Avatar
0JUICED1
Former Vendor
The only downside would be trying to get the tires to hook. You should pick up some low end power in general with a stroker motor but a lot still depends on the heads and cam you match it up with. To many variables. What kind of set up were you looking at?
Old Mar 29, 2012 | 10:53 AM
Levi Walker
I'm not sure yet. After reading your comment, it sounds like a great modification to me
Old Mar 29, 2012 | 11:08 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Less gas mileage if you keep you foot in it
I have a 414 (6peed) & 417(Auto) in C5s all pump gas................best bang for the $$$ when matched with your intended use, gear ratio and TC. Less weight, heat and rotating parts than FI too!
Steve
Old Mar 29, 2012 | 11:23 AM
Sinister-one's Avatar
Sinister-one
I'm aching to build a 427 stroker as soon as fund come available !!
Old Mar 29, 2012 | 12:24 PM
ctusser's Avatar
ctusser
There is really no downside for a street motor b/c increasing the stroke puts the power lower in the rpm range, where most of your street driving is done. If you want a really high RPM motor a short stroke big bore motor would be the better choice.
Old Mar 29, 2012 | 12:29 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by ctusser
There is really no downside for a street motor b/c increasing the stroke puts the power lower in the rpm range,.......
Instant "cubic torque"
Old Mar 29, 2012 | 12:48 PM
Paul 75 L82's Avatar
Paul 75 L82
I had a 383 stroker in a 72 Camaro and it was kick ***. I would love to have one in a C5.
Old Mar 29, 2012 | 01:08 PM
7LitreC5's Avatar
7LitreC5
You'll get slightly less gas mileage but not much. You will also have much less traction. You may want to visit the mini tub thread...
Old Mar 29, 2012 | 02:10 PM
Cruise-In V Veteran
NCM Ambassador
This is what the 97 sounds like with 2 inch kooks headers, 3 inch kooks offroad and stock catback............
And this is what it sounds like with 2 inch kooks headers, 3 inch kooks offroad and B&B Tri Flo Sport mufflers with by-pass mod I just put on
The 01' with the 414 sounds like......http://www.youtube.com/watch?v=eG_7w7uNbQ4
Old Mar 29, 2012 | 03:04 PM
AU N EGL's Avatar
AU N EGL
What do you want your car to do?
Then base your conversations with an engine builder about what you want your car to do?
Let that engine builder make suggestions. and Go from there
Old Mar 29, 2012 | 03:18 PM
Sinister-one
And he should know !!
Old Mar 30, 2012 | 08:10 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
No and yes
an engine is an airpump, its output can be calulated
slightly more oil consumption is the one thing you never hear people or shops say but that is one thing that does occur
To Stroker engine question
