blink then buzzer
Old Mar 29, 2012 | 03:22 PM
dcrflhr's Avatar
dcrflhr
Cruising
Default blink then buzzer
Now this is weird. When I use the turn signal it may work fine or it may blink maybe once or twice or not all. Then a buzzer will go off in the dash. I thought it might be a bad bulb but they all seem to be good...I'm at a loss. Will the flasher cause that?
It's a 2000 6 speed roadster with no mods.
Old Mar 29, 2012 | 03:47 PM
Bluefire's Avatar
Bluefire
I would assume the buzzing you hear is the flasher relay chattering. It could possibly be low voltage supplying the relay or just a bad relay.
HTH
Old Mar 29, 2012 | 04:09 PM
dcrflhr's Avatar
dcrflhr
Cruising
Thanks Bluefire.....I forgot to mention that the flashers stop when the buzzer starts
To blink then buzzer
