Removing Radiator ?
Old Mar 31, 2012 | 11:22 AM
BACNBLK's Avatar
BACNBLK
Default Removing Radiator ?
So unfortunately the stock radiator on my 2001 finally cracked at the water neck, evidentially plastic is not the most durable of products
Good news is I have a nice Aluminum Hvy Duty replacement on the way
So it looks fairly simple process to remove/replace: Drain, remove Shroud, replace with new Hoses, Refill, Burp and Drive.
Any Tips or hidden bolts/clamps that will stop me in my tracks at the worst time?
Any thing I should look out for, or advice on proper steps to take ?
Any help in advance is greatly appreciated as this is my next weekend project!
Thanks and
Old Mar 31, 2012 | 03:01 PM
Lothar34's Avatar
Lothar34
I've done it a few times. If your new radiator is thicker than the OEM thn getting the fans in may take some finagling. Othat than that, it's pretty simple.
Are you leaving the condenser in place? Every time I've removed the radiator, I also took out the condenser. I'm not sure it's doable with teh condenser in.
Old Mar 31, 2012 | 03:12 PM
LoneStarFRC's Avatar
LoneStarFRC
Pretty straightforward really. Depending on which brand of rad you chose, some very minor trimming of the radiator support shroud may be required. Be sure the round rubber grommet on the bottom (pass. side) is in place when stabbing in the new unit. It sometimes may get pulled out with the old radiator and get overlooked.
Btw, the AC condenser can stay in place, just use caution not to damage the fins, etc.
HTH
Old Mar 31, 2012 | 04:51 PM
BACNBLK's Avatar
BACNBLK
Got a new DeWitts on the way, so hopefully plug n play no trimming, although the unit is twice the size, so Dremel on the stand by if needed!
Besides the 4-bolts holding the shroud radiator support in place are there others that need removal or any other hidden clips?
What holds the fans in place, and are bolts easily accessible?
Thanks!
Old Mar 31, 2012 | 05:20 PM
LoneStarFRC
Originally Posted by BACNBLK
Got a new DeWitts on the way, so hopefully plug n play no trimming!
Besides the 4bolts holding the shroud radiator support in place are there others that need removal or hidden clips?
What holds the fans in place, are bolts easily accessible?
Thanks!
Fan housing assembly held in place by kind of a "hook" tab so-to-speak.
Have a pair of tin snips or sharp side-cutters (wire cutters) or a Dremel with a cut-off wheel attachment on hand. Unless DeWitts has changed their design, there will be a couple small cutouts/notches that need to be made in the plastic radiator shroud. No biggie really.
Old Mar 31, 2012 | 05:27 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Just took mine out this morning. Did not remove the condensor. Hardest part was opening all of the wire harness clips that were attached to the fan assembly and getting to the clamp on the lower radiator hose.
Old Mar 31, 2012 | 05:34 PM
BACNBLK's Avatar
BACNBLK
Very cool, sounds easy enough then, if any other tips are known please let me know!
Thanks!
Old Mar 31, 2012 | 08:10 PM
Bill Dearborn's Avatar
Bill Dearborn
On both my 97 and 03 the big problem was getting the fan shroud out and back in. The wiring harness on the front passenger side on both cars kept acted like a hook holding the lower tab on the shroud preventing me from pulling it out of the car. It took quite a while to get the harness moved enough so the shroud could be pulled up.
Bill
Old Apr 1, 2012 | 10:45 AM
BACNBLK's Avatar
BACNBLK
Good to know, thanks for the tip!
Amazing how some little tab or clip can stop progress in short order!
Also did you all replace T-Stat at same time, seems like that might be cheap insurance as well?
Old Apr 2, 2012 | 01:52 PM
waddisme's Avatar
waddisme
Might be a good time to go ahead and change those hoses if you haven't lately. Also, use an air compressor and clean out the a/c condensor as best as possible while you can get at the back of it. Good luck. I have the DeWitts and track the crap out of my car with temps never getting above 202*. Why people spend more for the Ron Davis I will never know.
Old Apr 2, 2012 | 02:41 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
You're halfway to the cam, so you might as well replace that while you're in there.
Old Apr 2, 2012 | 09:31 PM
BACNBLK's Avatar
BACNBLK
Now you are talking! That may be next
Looking forward to that, mine always ran a bit warm in Sacramento summer heat, all New Hoses and New T-Stat, fresh coolant, should be good for a few years!
Old Apr 2, 2012 | 10:12 PM
LoneStarFRC
I recommend distilled water with your Dex-Cool instead of tap. Cheap, plentiful, and no minerals.
Old Apr 2, 2012 | 10:53 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
That was what I was thinking when I saw this thread,,,really about 1/3 of the way,,,,but way worth it!
228 230 580 581 113 LSA,,,new car!
Old Apr 3, 2012 | 08:49 AM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
I'm secretely wishing for a radiator malfunction. If it overheats and takes the heads with it, even better.
Old Apr 3, 2012 | 03:59 PM
CHJ In Virginia's Avatar
CHJ In Virginia
One additional thing to look at while you have everything apart - the serpentine belts. You will never have an easier time to change them out especially the AC compressor belt. Check carefully for cracks or wear on the ribs. At 38K miles mine mime didn't need replacement, but since the car sees a lot of high RPM's on the track, I did them when the DeWitts radiator went in. I figured it was cheap insurance.
Old Apr 3, 2012 | 06:17 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
To Removing Radiator ?
Old Apr 3, 2012 | 06:59 PM
DBS99MagRedCoupe
Ordered my DeWitt radiator last week. Should be shipped any day now.
Old Apr 3, 2012 | 09:35 PM
BACNBLK's Avatar
BACNBLK
Yep, got that in the waiting as well, all new hoses, belts, clamps!
Old Apr 3, 2012 | 09:36 PM
BACNBLK's Avatar
BACNBLK
Mine shipped today, hope its here for the weekend!
