o2 C5Z Passenger Window Woes.
Old Mar 31, 2012 | 08:39 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
Default o2 C5Z Passenger Window Woes.
Ok so my passenger side window and door lock have not worked right since I purchased the car a month and a half ago. I change the door module today and the lock now works the window still does not. I replaced the regulator with a new one I have for my 99 coupe. Bad idea as it fits perfect, but the electrical connection is not the same I got the old one to work but when it is in the car it jams when the window is rolled up and will not roll down unless I rap on the motor with a wratchet... and it is noisy when rolling up. sounds nice and smooth on the way down, sounds bad going up though... any suggestions?
Old Apr 1, 2012 | 02:08 AM
egrand333's Avatar
egrand333
Install the new regulator again and get the required adapter for the electrical connection.
Old Apr 1, 2012 | 05:52 AM
Lt. Dan M.'s Avatar
Lt. Dan M.
That would be awesome, but where would I get the adapter?
Old Apr 1, 2012 | 10:12 AM
egrand333's Avatar
egrand333
I know RockAuto has them, maybe GM PartsHouse. Or even a Dealer, money saved on shipping might make it practical.
Old Apr 1, 2012 | 10:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The dealer has the adapter. Also, you need to verify which way the window goes up or down when you push the switch....when you are wiring up the adapter.
To o2 C5Z Passenger Window Woes.
