Please Help. Electrical problems
Old Apr 1, 2012 | 01:29 AM
Brian Alvstad's Avatar
Brian Alvstad
7th Gear
Default Please Help. Electrical problems
When I hit both my window buttons the same time my lights dim and my cd player like shuts off and turns back on...any one have any idea what is going on?
98 Corvette
Old Apr 1, 2012 | 01:53 AM
Dave68's Avatar
Dave68
It could be a ground issue. There's a sticky post above about cleaning grounds; check it out.
Old Apr 1, 2012 | 06:19 AM
Lt. Dan M.'s Avatar
Lt. Dan M.
I have 2 vetts and the lights dim on both of them when you operate the windows lol, I agree it is most likely a ground issue.
Old Apr 1, 2012 | 06:23 AM
dougbfresh's Avatar
dougbfresh
OR, one or both of the motors are pulling too much current. Taking the door panel off and lubing up the tracks for the window may make the motor not work so hard.
Old Apr 1, 2012 | 08:38 AM
4DRUSH's Avatar
4DRUSH
Don't press both buttons at the same time.
Old Apr 1, 2012 | 09:51 PM
Brian Alvstad
7th Gear
I was told it could be the alternator...what ya think?
Old Apr 1, 2012 | 10:23 PM
65GGvert's Avatar
65GGvert
Not likely, but you could have loose or corroded connections on the battery cables or the red wire on the starter solenoid that connects the alternator, starter solenoid and battery 12v all together. Either the battery or the connections are causing the voltage to dip low enough to affect the cd player. Have you noticed any settings defaulting, like the HUD defaulting to oil temp when you set it to fuel last time you drove? Those type things could mean your battery isn't up to snuff. If the only time you have any trouble is when you press both switches at the same time, I would tend to agree with the "don't press both at the same time".
Old Apr 1, 2012 | 10:32 PM
Brian Alvstad
7th Gear
even when im not doing anything the lights dimmer also. like flicker..and no the settings dont reset on my stereo
Old Apr 1, 2012 | 10:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
How old is the battery? Have you checked both the battery and starter solenoid connections? I mention the starter solenoid because this is where the battery, starter and alternator all come together.
To Please Help. Electrical problems
