Problems with front turn signals burning out. Moisture?
Thanks!
I need to replace the sockets..as far as replacing the light housings themselves see the DIY sticky in C5 tech...
The ONLY long term solution, even if you do not buy the clear aftermarket corners. Period. Either buy new stock (or aftermarket) housings and load them with LED bulbs or repair the old ones and buy LED bulbs. Either way, DO NOT just keep loading incandescent bulbs back into the housing.
Bill
I posted this a while ago which might help.
Melted turn signal housings are common and its a design problem on all C5s. The turn signal bulbs are dual filament and act as park, turn and DRLs. The heat of the DRLs being on constantly burns the housing. I had to inhibit the DRLs here in England as ambers are not legal here. I never have T/S bulb failures and my lenses are still sound. The most common symptom is that the bulbs fail regularly because water gets into the bulb holder.
You can inhibit the DRLs by pulling the A2 fuse but if you want to keep the DRLs, LEDs are the way to go. LED bulbs produce less heat and are less likely to damage the housing. If you fit LEDs you’ll need a ballast mod to prevent “hyperflashing” as the system doesn’t recognize the LED bulb and thinks it’s failed. (JWMotoring sell a harness which will fix that issue).
Pull the housing – I’ve attached a procedure below – and inspect it. Others prefer to go in through the headlight housing but its harder to see the fixtures. You’ll probably find a hole on top. If it’s not too bad seal it with silicon sealant and reinstall the housing. That should fix the problem for now and the silicon may be enough to stop it getting worse.
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Bill
Even though I'm an advocate of LEDs (for several reasons), I agree Bill. For those so inclined, and for whom their housings are not toasted beyond any cost-effective repair, this could be a very viable option.
I think a 2" (minimum) hole, using a hole-saw, cut directly above where the bulb is positioned and the use of JB Weld for sealing would be a good approach. Additionally, I would try to make a slight "dome" shape in the metal as much as possible to gain as much additional clearance as possible over the bulb. Only problem there though may be the fact that the bracket (shark cage) also sits directly above the housing and doesn't leave much room for clearance unless you also cut a relief hole in it as well.
As far as material, even something thin like a patch made from a soda can might work well since it's easily formed by hand and trimmed by scissors if necessary.
The constant high heat from the bulb coupled with a poor design (bulb too close to the housing) leads to failure after failure.Though posted before, a repost of the removal procedure from the FSM is a good idea from time to time. Thanks Dave.
BTW the last pic is looking up where the bulb would twist in (as if you were sitting on the floor looking up)...see that hole/crack at the very top? Thats where the heat melted through...
Good luck.
