Inner Tie Rod Tool Size?
Old Apr 3, 2012 | 08:00 PM
Turbopower87's Avatar
Turbopower87
Default Inner Tie Rod Tool Size?
Can someone please tell me the correct size of the flats on the front inner tie rods? It appears to be metric as none of the US sized adaptors available to me worked. Believe it or not Google has failed me in my searching.
Old Apr 3, 2012 | 09:08 PM
FourG63 97GST's Avatar
FourG63 97GST
I don't like guessing, but my hand is reaching for the 13mm right, I've done alot of alignments, an the majority was 13 for me, what standard fit the best?
Old Apr 3, 2012 | 09:39 PM
Turbopower87
13mm is definitely way too small for the C5. The closest was 1 7/16 which was slightly too big and kept popping off. The next smallest size I saw in a metric kit online is 33.6mm.
Thank you for your guess though. I will be able to measure it tomorrow afternoon, I was just hoping to order an adaptor online tonight in hopes of receiving it in time to do the swap this weekend. I'll post up the measurement for future use.
Old Apr 3, 2012 | 09:52 PM
Bill Dearborn's Avatar
Bill Dearborn
GM hasn't used English fasteners on the Corvette since the 82 went out of production. C5 and C6 tie rod adjusters take a 13mm wrench.
Bill
FourG63 97GST
ahh thought you meant the groove on the rod itself, I usually use an adjustable on the nut
Old Apr 3, 2012 | 10:11 PM
Turbopower87
I'm talking about removing the entire inner tie rod from the rack in order to replace them.
Old Apr 4, 2012 | 12:50 PM
Turbopower87
I measured the stock inner tie rod flats to be 1.413 inch = 35.9mm = 36mm wrench
The Moog replacement has two sets of flats, one measures 1.413 inch and the other 1.408 inch.
To Inner Tie Rod Tool Size?
