Replacing C5 Thermostat?
Old Apr 5, 2012 | 08:58 AM
BACNBLK's Avatar
BACNBLK
Default Replacing C5 Thermostat?
Bad news is OEM Radiator finally cracked, Great News a brand new DeWitt arrives today!
Besides replacing with all new hoses and coolant, also decided good time for brand new thermostat. Everything brand new!
Question: it appears the T-Stat is a two piece design including stat and water neck housing, ok, more than what is needed but whatever, do I need to use RTV Sealant around the water neck housing, there was only a small rubber washer for around the stat?
What about the larger surface area, am I missing a needed gasket?
Do I use some RTV? Is nothing needed there?
Appreciate any help, thanks!
Old Apr 5, 2012 | 12:11 PM
machz800ps's Avatar
machz800ps
No rtv just use o-ring!!!
Steve
Old Apr 5, 2012 | 12:12 PM
bumble-z's Avatar
bumble-z
Apply silicone grease to o ring, to hold it in place
Apply anti seize to threads of bolt.
Apply 89 INCH.LB of torque to bolts
Good luck
Old Apr 5, 2012 | 10:20 PM
BACNBLK's Avatar
BACNBLK
Thanks guys, seemed like something was missing, will do!
New Radiator showed up today, a day early, I am drooling at getting her done!
Tomorrow night , game on!
Old May 16, 2014 | 02:03 AM
Frankie 69's Avatar
Frankie 69
8th Gear
My 2002 with LS1 engine has a one piece thermostat/housing unit with an o-ring. The thermostat cannot be separated from the housing and the whole unit must be replaced.
Old May 16, 2014 | 07:18 AM
vettenuts's Avatar
vettenuts
Can you post a photo of the stat you have? Something doesn't sound right and I am wondering if you have the one for the replacement water pump rather than the original water pump.
Old May 16, 2014 | 09:55 AM
NukeC5's Avatar
NukeC5
Not to start a war, but make sure to use the stock temp thermo, this has been discussed a lot on here.
Old May 16, 2014 | 05:13 PM
aaronc7's Avatar
aaronc7
I was so baffled when I first came on the Corvette forums with all talk of going with a cooler tstat for street cars. I would agree that stock is best.... 180F would be fine too.
Old May 17, 2014 | 03:29 AM
baxsom's Avatar
baxsom
That does get discussed around here a lot. I decided that I would go with whatever the company I was paying to build my engine recommended and then didnt even ask.
Old May 23, 2014 | 02:49 PM
Frankie 69's Avatar
Frankie 69
8th Gear
Don't have a photo, but it is my understanding that all C5s (except late 2004s) came with the combined thermostat/inlet housing. If you still have an original water pump with casting #12562459, you have to buy the whole thermostat/inlet housing when replacing the thermostat. But now when you buy a replacement water pump from GM, it is of more conventional style with a replaceable thermostat. Confusing, isn't it.
Old May 23, 2014 | 03:12 PM
RedZMonte's Avatar
RedZMonte
mine is a 04 with a housing and stat as one.. when i ordered the new one they offered separate stat from housing.. they switched at some point.. dont remember when.
To Replacing C5 Thermostat?
