Intermittent High Speed Vibration With New Wheels
Old Apr 5, 2012 | 10:34 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Default Intermittent High Speed Vibration With New Wheels
I bought a brand new set of 17/18reproduction Z06 Motorsport wheels a few weeks ago..I've been battling a high speed vibration that comes in waves...there for a second gone for a second...there for a second...etc. I feel it in my seat not in the steering wheel which leads me to believe it's coming from the back tires. A tire shop mounted balanced and road forced them. They are the stock Goodyear emt's and with the stock wheels I don't remember any vibration. I had a set of repro Z06's and non runflats on I was "borrowing" from my Trans Am from aug-march till I fixed it and there was no vibration. I had another shop check the balance in the back wheels today and although one of the tires was a 1/4 ounce off it didn't fix my problem. So could this be a(the)wheels?
Old Apr 6, 2012 | 08:35 AM
AU N EGL's Avatar
AU N EGL
YES. the rims may need to be balanced on their own.
Old Apr 6, 2012 | 09:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Either out of balance overall as in the balance person didn't do it right or the rims could be out of round or just plain old manufactured poorly. I've heard several times there's some nice looking but cheap Chinese rims out there that won't work very well. Its also possible you have a bad tire(s).
Old Apr 6, 2012 | 10:42 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Well I had two different shops balance the rear tires and if it was a tire I would have felt it with the stock wheels which I didn't. I heard about the cheap chinese wheels and while these were pretty cheap off ebay($550+shipping) I don't know where they were made but like I said I justt took off a set of repro Z06's I put back on my Trans Am and they ride smooth.
Old Apr 6, 2012 | 10:51 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Twice happened for me. Aftermarket wheels very often do not meet the stringent specifications of OEM wheels. There simply isn't adequate quality control. I had to buy 5 wheels from Factory Reproductions to get 4 decent ones. $900 tied up and lots of trips to the installer, Discount Tire, who even ate the cost of a new tire just to find out what was wrong. I ended up getting the vibration almost completely gone by manipulating tire pressure from one side to the next. It works quite well, but should never be necessary. It's too late for you now, but when buying such wheels always test spin them for trueness BEFORE mounting them with tires. You can see the out of roundness as it spins on the hub of your car, or on the balancing machine. Anything more that .100 of an inch cannot be fixed.
Old Apr 6, 2012 | 11:02 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
I have the tire pressure set at 35psi what produces less vibration raising or lowering pressure? It will ride better with lower pressure but I might get worse gas mileage right?
Old Apr 6, 2012 | 02:20 PM
corvettebob1's Avatar
corvettebob1
Just because they road force balanced your tires doesn't mean they will run smooth.
I had a brand new Goodyear GS-D3 with 27lbs of road force and it did the same thing your car is doing.
After much searching I found the magic number is 17lbs if it's more then that the tire is defective.
Old Apr 6, 2012 | 05:55 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Well like I said if it were the tires I think I would have felt it with the stock wheels.They were sitting on the side of my house the past 7 months but I don't think that did anything to them.
Old Apr 6, 2012 | 09:02 PM
$$$frumnuttin'
I suspect every car will be different...on mine I run 3 psi less on the passenger front compared to the driver side....this gives me the smoothest response. There may be other combinations that work too. It's all trial and error, but if you know someone who races professionally they should be able to assess your ride or at least give you some suggestions. Also, I have adjustable coilovers, so they play a role too in front suspension characteristics......the whole thing is like shooting in the dark.
Old Apr 7, 2012 | 03:13 AM
striper's Avatar
striper
Did you remove the clips that hold the brake rotor on to the wheel studs? Aftermarket wheels do not usually have the recess to accomodate the clips and will make your wheels feel like you have a balance problem. I found this out when I changed wheels on my own car.
Old Apr 7, 2012 | 10:07 AM
ALLEGRO's Avatar
ALLEGRO
Hummmmmm
Old Apr 7, 2012 | 10:51 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
I was told about the clips possibly being the problem by the shop who mounted them the next day and no I haven't looked however like I said I just had a set of chrome z06's just on the car with a different set of tires and there was no vibration. I also asked the other shop the other day when they took off my rears if they saw any clips when they took them off they said no.
Old May 7, 2012 | 11:19 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Well I took the car back to the original shop(Performance Tire And Wheel) in Orange City, Florida. The owner balanced and road forced the rear tires again and the high speed intermittent vibration seems to be gone! I can drive on the highway now without my teeth chattering. He said the wheels were good. Amazingly, he tried to charge me $23 for the labor and I told him I already paid him for the job the first time and I've been driving around with an annoyimg vibration for 2 months because he didn't do it right then. He wasn't happy and said "oh you're going to be like that and I worked 1/2 hour on your car today" called me up and hung up the phone on me and said "get tires some where else!" I had spoke with him earlier about getting a set of non run flat tires within the next couple months. Um I don't need you sir I can get tires any where...you need customers and you just lost one.
To Intermittent High Speed Vibration With New Wheels
