I'm interested in a bigger camshaft for ls1. I dont want to race the car alot maybe a few times a year on a small drag or something. Its just the love for that 'muscle car' music and makes heart happyer.
So if i was enough accurate what i want, what cam size would be enough for me? i dont need hell of a horse power, maybe just a few ponys
Also, what should be replaced while being in work, are lifters/springs a must? tune?
WOW,,, thats a loaded question Theres a LOT of "IF's" that are involved in cam selection.
- AUTO or Manual Trans???
- Mods Now and future Mods???
- Do you have headers??
- Do you want a wide power band or a top end power band???
- Do you want a lot of cam LOPE or little LOPE??
Durations below 230 are considered small cams. They can easily get you 390-400 HP with supporting mods. There more friendly to automatic Trans cars. The bigger the cam, the more you will need a High Stall Converter for an AUTO Trans. The more cam and power that you make, you will have to seriously consider a LOT of drive train mods.. Like: Hardened rearend output shafts, trans/differential brace up-graded clutch OR up-graded trans and a high stall converter.
Durations above 230 to 240's are fairly healthy cams that make lots of power 400-500 HP
Durations in the high 240's to +++ require a LOT of work to fit and work.
You also need to consider the cams LSA and Lift The 230 and below are usually less than .600 " lift Usually around 580's
Any cam will require New Performance valve springs, fitted push rods and a TUNE
BC
Thats alot of work. I knew it takes time and patience, but didnt think it would need so mutch attention on other stuffsection parts too.
since its such a big project and in the end so many horse power, i might take a big consideration and maybe think about this in winter, car is in storage for the winter time
