Name this module
Old Apr 11, 2012 | 07:38 PM
sx spd c-5's Avatar
sx spd c-5
Default Name this module
I replaced the blower motor module today (had an issue with thw HVAC blower starting while the key was off)
Removed the lower panel and this fell down. It is hooked in to the blower module wiring???
Old Apr 11, 2012 | 07:57 PM
Lothar34's Avatar
Lothar34
Do you not have the Google where you live?
http://articles.chicagotribune.com/2...tor-fins-dryer
...Many solutions to this problem involve the professional application of a biocide. But if you own a General Motors car or light truck built in the last decade, there is another alternative: an electronic evaporator dryer available from GM dealers as part No. 12497910 or from AC Delco as part No. 15-5876. An earlier version came out a couple years ago...
Old Apr 11, 2012 | 08:23 PM
dougbfresh's Avatar
dougbfresh
A part number even and google why would you need help.
Old Apr 11, 2012 | 08:36 PM
sx spd c-5's Avatar
sx spd c-5
Default Thanks
Where were you geniuses when I asked why the HVAC fan was coming on after the key is off???
http://forums.corvetteforum.com/c5-t...n-cycling.html
Old Apr 11, 2012 | 09:14 PM
Lothar34's Avatar
Lothar34
Well if you had mentioned in that thread that you had that module installed, then we may have had a better answer for you.
Old Apr 11, 2012 | 09:22 PM
Paul 75 L82's Avatar
Paul 75 L82
I have the same on mine. There was a service bulletin from GM, that if the owner complained about a mold smell to install this module. It turns on the blower fan on twice during the first 20 minutes after the car has been turned off to blow the water off of the AC coil so the water would not sit there and mold. I live in South Florida and I'm glad I have it. My car never smells musty.
To Name this module
