Re-Programming Tire Pressure Sensors?????
Old May 19, 2002 | 03:11 PM
jetskifast's Avatar
jetskifast
Default Re: Re-Programming Tire Pressure Sensors????? (Buckmaster)
Magnet goes on side of valve stem ;)
Old May 19, 2002 | 03:44 PM
jetskifast's Avatar
jetskifast
How big should the magnet be?
I used a small 5 LBS magnet. Placed on valve stem side, resting on rim.
Old May 19, 2002 | 04:03 PM
quenchmasterc5's Avatar
quenchmasterc5
Default Re: Re-Programming Tire Pressure Sensors????? (jetskifast)
Almost any magnet will do, but should be about 1 inch in diameter and placed inside and against the wheel surface at the point of the valve stem, be patient, it takes about 5-8 seconds each. Make sure the DIC reads starts at the "Left Front" first. Good luck
Old May 19, 2002 | 04:15 PM
C5 Frederik's Avatar
C5 Frederik
If you start left front and maybe left front sensor is dead, you cannot proceed the programming.
So try again with starting programming at front right or rear right. If you again do not get a horn.........I do not know what to do then. If you get a horn, front left is dead.
Frederik
Old May 19, 2002 | 07:26 PM
quenchmasterc5
Probably not, you need to get it on the inside of the wheel near the stem.
Old May 19, 2002 | 09:38 PM
see5's Avatar
see5
Buck'
It says in the manual that it may take 3 tries. Do you have the manual instructions??
Send me an email and I wiil send them to you.
I did this for my new wheels.
Old May 19, 2002 | 11:33 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
buckmaster,
first make sure your battery is fully charged. if it's not it won't allow you to program the sensors.
also if you slightly move (wiggle) the magnet around the base of the valve stem that seems to help.
if you check the c5 tech tip section the programming procedure is there.
Old May 20, 2002 | 12:13 AM
laserman's Avatar
laserman
I just re-programmed mine and I used a U shaped magnet, I did not touch the rim or stem at all. The magnet is about 2" tall by 2" wide and 1/2" thick.
Old May 20, 2002 | 01:43 PM
EHS's Avatar
EHS
Just did this on OEM Z06 wheels with no problems. Try placing it over the stem (if the magnet has a hole in it). The stronger the magnet, the easier the process.
Are you using your old sensors, that is, you know they are all good?
Old May 20, 2002 | 04:48 PM
EHS's Avatar
EHS
As a matter of fact, I bought my Z06 take-off wheels from Nate. Nice condition.
But I did not go with the package deal, so that I could, ahhh..., verify the integrity of the sensors. In other words, I bought new ones. I understand the batteries in them last about 5-7 years.
I guess you can pretty much guess the next step.
But before you chew up those HREs taking them apart, try putting a different wheel on the front left -- just to test the sensors. If the sequence fires up, you know you have a bad/missing sensor in the front left.
Just a thought. Hope this helps. :smash:
Old May 21, 2002 | 04:27 AM
C5 Frederik
Maybe I did not describe it well.....so once again.....
when the DIC asks you to start left front, just go to right front and start there, it doésn´t matter because it´s only a test. When you get a horn there, then left front is damaged
Fredrerik
Old May 21, 2002 | 01:44 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Re-Programming Tire Pressure Sensors????? (C5 Frederik)
I recently reprogrammed mine when I put on new HRE's. I picked up the magnets from radio shack - the largest they have. What seemed to work best is touching the side of the valve stem for about 5-8 seconds, and then stepping back away from the car. The horn sounded several seconds after moving away from the car. Weird...
-Jeremy
Old May 21, 2002 | 01:51 PM
EHS's Avatar
EHS
Default Re: Re-Programming Tire Pressure Sensors????? (Godspeed)
Jeremy:
Not at all weird, that is actually a quite common phenomenon called "anaception."
:yesnod:
Old May 22, 2002 | 12:21 PM
C5 Frederik
...... DIC says start with the Left Front and I cannot get beyond that
If I always would do what my DIC says........ :D :D :D :D
Frederik
To Re-Programming Tire Pressure Sensors?????
