LS7 in C5 SWAP
Old Apr 13, 2012 | 05:36 AM
superramvette2's Avatar
superramvette2
Default LS7 in C5 SWAP
Okay I have done a lot of searching but I am still unclear on a few things
I basically have a stock ls7 longblock right now minus the rocker arms. I am swapping this into my c5.
Parts I have currently,
ls7 intake injectors, fuel rail.
ls7 shortblock
ls7 heads, pushrods, lifters, oil pan gasket.
lingenfelter 24 x to 58 X adapter.
Parts that I know I need,
Drill and tap for dipstick
injector adapter
knock sensor extensions
map adapter
My questions come from the oiling and cam part mainly.
Do I use a stock ls2 timing cover?
Which cam gears do I use? The stock ls7 one or ls2 cam gears?
Which oil pump?
I am pretty sure my stock batwing and pickup works for the oil pan
Which cam do I order? there are different 3 bolt and 1 bolt cams now and I am not sure which one i order for this conversion?
Which timing chain?
Any help will be appreciated.
Old Apr 13, 2012 | 11:08 AM
7LitreC5's Avatar
7LitreC5
I run an LS2 cover and pump in mine. The stock timing chain should be fine. If you have a timing chain already I would order a cam that matches whatever type it is. If not I would get a 3 bolt since they are a little more common.
Old Apr 13, 2012 | 02:20 PM
superramvette2
Stock.ls7 timing chain? Or stock ls1 chain?
Old Apr 13, 2012 | 02:31 PM
7LitreC5's Avatar
7LitreC5
As long as you have the correct 3/1 bolt version they will all work to the best of my knowledge. I happen to be running a 3-bolt LS2 chain in mine.
Old Apr 14, 2012 | 04:32 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
Get rid of the LS1 oil pan and get an LS2, it will give you way more room for other things like working on headers or oil cooler lines.
Old Apr 14, 2012 | 04:53 PM
7LitreC5's Avatar
7LitreC5
Excellent suggestion. I did that when I did mine and it makes it way easier to wrok on!
Old Apr 14, 2012 | 08:40 PM
427TTA4's Avatar
427TTA4
But he is buying the lpe box so doesnt that mean he should stay with the ls3 timing chain setup???
Old Apr 14, 2012 | 08:58 PM
7LitreC5's Avatar
7LitreC5
The LPE box is for the crank position sensor. The upper timing gear has to do with the cam position sensor.
Old Apr 15, 2012 | 01:29 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
If you are changing over to the wet sump, make sure you get a crank spacer for the balancer since the LS7 has the longer crank snout.
Here is a very good write up form Hot Rod magazine with the parts list and where to get them.
http://www.hotrod.com/techarticles/e...n/viewall.html
__________________
Old Apr 16, 2012 | 01:09 AM
superramvette2
I have the spacer from scoggin dickey. I thought about doing a write up thread on this swap since there are not any. I have been taking a lot of pictures so far. I am pretty impressed with the stock ls7 heads, much better than I expected.
I ordered a cam kit with springs from ragin racing this weekend. Looks like it will be this one
Stalker 224/246 115 1800-6800 powerband excellant power through out great drivability Choppy idle
Old Apr 16, 2012 | 04:48 AM
detroitr's Avatar
detroitr
A write up would be awesome
Old Apr 30, 2012 | 02:16 AM
superramvette2
So which upper timing gear do I need? I have the ls2 timing cover and sensor now. Can I use the ls7 timing gear?
Old Apr 30, 2012 | 07:49 AM
7LitreC5's Avatar
7LitreC5
That will work fine. It's what I am running in mine.
Old Apr 30, 2012 | 10:49 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
We've done several LS7 to C5 swaps that include the dry sump and can supply all the necessary pieces (tank, lines, fitting, etc) to make it look like a factory installed dry sump.
If this interests you, give us a call.
ls7 shortblock
injector adapter
map adapter
Which oil pump?
Which timing chain?
To LS7 in C5 SWAP
