Quite by accident, I ran across this. Has anyone ever seen or heard of this or a similar product? For $225, I'm tempted to just give this a try but is it just snake oil? If indeed this was viable, the HP gain for the money spent would be tremendous. Replies?
Thanks kindly gentlemen. That is exactly what I figured it was. I'd never heard of it before though and thought it all sounded too good to be true. Thank you for your quick and intelligent responses and for saving me some $$$. I like saving $$$...
Trade - off - weight of batteries / running belt from engine...
Not to mention the battery version is not mechanically linked regarding throttle and engine load etc. Still not sure if that is even safe, if the engine were to ever lose a sensor etc.
Haha I was just joking anyways. You could easily control the motor speed based on an RPM signal. Using a couple sensors you could define panic ranges where you cut off boost if you sense something has gone amok.
