My 2002 Engine Taps.....
Old May 19, 2002 | 06:51 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Default My 2002 Engine Taps.....
My 2002 MN6 has about 300 miles on it now and I have noticed that when you first crank it, it sounds like something is tapping very loud under the hood after driving a few miles it stops and is fine for the rest of the trip. What the heck is this? I have read a few posts in the past about something like this, but can't find them now. The tapping IS related to RPMs in that it gets faster as you push the gas pedal. :confused:
Old May 19, 2002 | 06:56 PM
MDT's Avatar
MDT
Default Re: My 2002 Engine Taps..... (LowFlight)
LowFlight,
Sounds like the old piston slap problem. If it was a lifter, I think it would pump up in a matter of seconds.
Good luck.
Mark
Old May 19, 2002 | 08:01 PM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Default Re: My 2002 Engine Taps..... (MDT)
Piston Slap, that is what was happening. Is there a fix from GM or is that the way of the car or what?
gojo's Avatar
gojo
put new link below
[Modified by jfpilla, 12:44 AM 5/20/2002]
Old May 19, 2002 | 08:08 PM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Default Re: My 2002 Engine Taps..... (jfpilla)
Go here and index to oil use.
http://www.idavette.net/hib/ls1c.html
[Modified by jfpilla, 12:06 AM 5/20/2002]
:confused:
Old May 19, 2002 | 08:42 PM
gojo's Avatar
gojo
Sorry, gave you wrong link. http://www.c5registry.com./2k2z06/page5.htm
Old May 19, 2002 | 08:57 PM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Thanks...I can live with it as long as nothing is being damaged. It is doing exactly what the article said at the bottom about the knocking. It isn't using any oil etc...Thanks
Old May 19, 2002 | 09:04 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
my 02 also taps when cold but it has becomes less as i get more miles on it. i now have about 900 miles and i hardly hear it now. :chevy
Old May 26, 2002 | 06:16 AM
LIGHTNING's Avatar
LIGHTNING
I've heard the same thing in every chevy i've owned...'96 lumina, '00 c5, friend's '02 impala
Old May 26, 2002 | 08:26 AM
Crushinator's Avatar
Crushinator
Default Re: My 2002 Engine Taps..... (LIGHTNING)
It's funny but my current Corvette is the first Chevy I've ever owned that doesn't make that noise. All my Z28's and my '96 LT4 made that tapping noise. I just learned to live with it.
Old May 27, 2002 | 01:08 AM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Fuel Injectors?
Old May 27, 2002 | 02:17 AM
TooManyIDs's Avatar
TooManyIDs
"In mid-April ’01, there was a change in the LS1/LS6 piston which will carry over to MY02...."
Your 2002 should have the fix.
To My 2002 Engine Taps.....
