Vacuum hose missing??? Pic inside
Old Apr 15, 2012 | 04:25 PM
JimInPA's Avatar
JimInPA
Default Vacuum hose missing??? Pic inside
Am I missing a vacuum hose on my throttle body? See pic- Almost dead center in the pic, above the coolant hose and below the split loom tubing with the pink wire. Is there supposed to be a hose there? If so where does it go? Thanks for any and all info!
Jim
Old Apr 15, 2012 | 04:36 PM
Zorlac's Avatar
Zorlac
I think that is where the coolant used to run through the TB. It looks like someone did the coolant bypass. I may be wrong. One of the gurus will chime in shortly.
Old Apr 15, 2012 | 04:37 PM
CARRJET's Avatar
CARRJET
coolant loop for keeping throttle body warm?
Old Apr 15, 2012 | 04:44 PM
Lothar34's Avatar
Lothar34
I concur.
Old Apr 15, 2012 | 04:50 PM
Dennis Wilson's Avatar
Dennis Wilson
Thats what it is.
Old Apr 15, 2012 | 04:53 PM
JimInPA's Avatar
JimInPA
Ok- I searched the forum for coolant bypass and you guys nailed it. You are all gurus! Thanks for such a quick answer.
Jim
Old Apr 15, 2012 | 05:23 PM
Ole Blaster's Avatar
Ole Blaster
Jim
I would slip a rubber plug on it,, if it were me..
Old Apr 15, 2012 | 05:59 PM
DARRYLZO6's Avatar
DARRYLZO6
Plug it up.
m6 c5's Avatar
m6 c5
Same here
To Vacuum hose missing??? Pic inside
