Why would I get a B0516 H code ??
Old May 20, 2002 | 11:53 AM
jerryv's Avatar
jerryv
Default Why would I get a B0516 H code ??
'02 Z06 .. The book says the IPC detected vehicle speed in excess of 200 mph. :eek: I don't think so :) Haven't fallen off any cliffs lately. Anyone have an idea what else might cause this code? I cleared it and will monitor to see if it repeats.
Old May 20, 2002 | 01:46 PM
jerryv's Avatar
jerryv
Default Re: Why would I get a B0516 H code ?? (Jerry Velders)
Anyone? ttt
Old May 20, 2002 | 06:57 PM
Bugster57's Avatar
Bugster57
Check VSS connections at the rearend. I believe it's on the top. Check speedometer operation at all speeds. Chances are a connector problem caused the loss of the signal between the VSS and the PCM, that can throw a code according to the SM. Troubleshooting is limited to checking connections, without a scan tool to run diags on the modules, and in fact connection problems usually are the culprits. :yesnod:
"It's gotta be something simple... cause we can't fix the hard ones". :nonod:
Old May 20, 2002 | 08:06 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Hi there,
Jerry, there is a simple communications glitch there.
I have seen this a number of times, all in different vehicles. Not a problem, simply clear the code, and you will be fine.
If the code reappears, then appropriate diagnostics should be performed.
Besttoyou, c4c5 :crazy:
Old May 21, 2002 | 10:29 AM
jerryv's Avatar
jerryv
Thanks guys. :)
Old May 21, 2002 | 11:07 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Could be the VSS.
You don't have any teenagers, do you? That could explain it! LOL :D
To Why would I get a B0516 H code ??
