2000 battery drain problem
Old Apr 22, 2012 | 02:58 PM
RandyA's Avatar
RandyA
Default 2000 battery drain problem
My 2000 has a battery drain problem. I’ve got a 1.5amp drain on the battery sitting with nothing on. I measured this by disconnecting the plus battery terminal and hooking in an ammeter in-line. In a very quiet room you can hear what sounds like a very small electric motor or a very small subdued relay rattle coming from behind the passenger headlight. I can rotate the headlight motor without any resistance, so I don't think it's going through the motor. While I'm new to the codes I've checked and don't get any diagnostics to speak of. I don't know if this sound is the total cause of the problem. Any suggestions on what to check for to fix this. I thank you in advance
RandyA
Old Apr 23, 2012 | 06:49 AM
dougbfresh's Avatar
dougbfresh
AIR pump is back there I think.
Old Apr 23, 2012 | 08:37 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Pulling the fuses one at a time, until the current reading displayed on the in-line ammeter drops, should pinpoint the source of the current drain.
Old Apr 24, 2012 | 06:52 PM
RandyA's Avatar
RandyA
Thanks for the reply. I found a faulty seat switch. Haven't had time for the amp check. I'll gat back later--Thanks--RandyA
To 2000 battery drain problem
