Lots of Codes! help!
Old Apr 23, 2012 | 11:15 PM
c52korvette's Avatar
c52korvette
Default Lots of Codes! help!
Hey all. Just posting the many codes I have. Seeing all these codes leaves me not driving the car at all. Just want to see what best advice I can get from you all from here. Thanks appreciate all of you time in advance.
10-PCM
-P0442 H C - Evap system, small leak
-P0530 H - A/C Refrigerant Pressure Sensor Circuit
-P1626 H - Theft Deterrent System Fuel Enable Circuit
-P1631 H - Theft Deterrent System Password Incorrect
28-TCS
-C1226 H - Excessive Wheel Speed Variation
58-SDM
-U1301 H - Class 2 Circuit Shorted to Battery
60-IPC
-B0521 H - Tachometer Signal Circuit Malfunction
-U1255 H - Generic Loss Communications
-U1016 H - Loss of Communications with PCM
-U1064 H - Loss of Communications with BCM
-U1040 H - Loss of Communications with TCS
-U1088 H - Loss of Communications with SDM
-U1176 H - Loss of Communications with RFA
-U1160 H - Loss of Communications with LDCM
80-RADIO
-U1096 H - Loss of Communications with IPC
A0-LDCM
-B2232 H - Mirror Up Switch Fault
-B2252 H - Key Cylinder Switch Fault
-B2204 H - Left Window Down Switch Fault
-B2206 H - Right Window Up Switch Fault
-B2282 H - Battery #1 Fault
-B2284 H - Battery #2 Fault
-B2276 H - Door Lock Motor/Mirror Heater Fit
A1-RDCM
-B2205 H - Right Window Down Switch Fault
-B2283 H - Battery #1 Fault
-B2285 H - Battery #2 Fault
B0-RFA
-C2110 H C - Right Rear TPM Sensor Malfunction
Old Apr 24, 2012 | 06:34 AM
servohead's Avatar
servohead
Check your BCM for water intrusion.
Old Apr 24, 2012 | 08:47 AM
4 KRUSIN's Avatar
4 KRUSIN
Yep, this happened to me. Spiders built a nest in the HVAC overflow tube backing the water up and ultimately draining it on to th BCM.
To Lots of Codes! help!
